Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Join Date
    Oct 2019
    Location
    Adelaide, SA
    Posts
    946
    Default
    Awesome, keep us posted.
  2. #17
    Join Date
    Oct 2004
    Location
    Southern Highlands NSW
    Posts
    1,865
    Default
    I used a 6mm reamer on the PLA gear's bore, to match the spindle's diameter.
    For a positive drive, I installed a 1.5mm roll pin into the spindle, and put open-ended slots on the gear.
    That method also makes it easy to remove and install new gears.
    I'll put it on the motorbike tomorrow and, weather permitting, take it for a trial run.
    Attached Images Attached Images
  3. #18
    Join Date
    Oct 2004
    Location
    Posts
    1,865
    Default
    A little more progress - the drive assembly is installed to the wheel, ready to test.
    I have some silicone paste for electrical use, so I used that for lubricating the gears (plastic to metal) as it's greasy stuff.
    I'll keep an eye on it in case it melts in use.
    The spindle turns when the wheel is spun. That in itself is promising, as I made some guesses for working out the gear's required helix angle.
    I've run out of time today, and will report further when I've had a chance to go for a ride.
  4. #19
    Join Date
    Oct 2004
    Location
    Posts
    1,865
    Default
    Today I took the motorbike for a 50km ride to test the speedo operation.
    It works fine, so far.
    After some more distance, I'll disassemble the speedo drive gearbox, inspect and report here.
  5. #20
    Join Date
    Oct 2004
    Location
    Posts
    1,865
    Default
    Weather is getting better for motorbike riding, so I added another 70km on the odometer today.
    Total = 120km on the new printed plastic speedo drive gear.
    It's functioning well so far.
    Jordan
  6. #21
    Join Date
    Oct 2004
    Location
    Posts
    1,865
    Default
    I went for a weekend ride, now have 300 kilometers on the PLA gear.
    It has worked perfectly so far.
    Removed and cleaned, result is a slightly more furry-looking gear, with wear on the ends of the helical teeth.
    The wear is on the opposite sides, compared to the original steel gear, and about the same worn width of about half the tooth flank at the ends.
    It is progressively less towards the centre, where there is evidently no wear.
    My guess of 40 degrees instead of the original 30 may need to be adjusted to 35 degrees, for a better result in future.
    I will use the PLA gear until failure. It may be that it'll last long enough to put up with regular new replacements.
    It is very easy to remove and replace.
    It's nice knowing that the steel worm gear it meshes with won't be distressed by the soft plastic imperfect gear.
Similar Threads
  1. Replies: 0
    Last Post: 13th Apr 2018, 07:45 PM
  2. Where to find small gear cutters
    By Michael G in forum METALWORK GENERAL
    Last Post: 28th Sep 2016, 03:39 PM
  3. VSD suggestion
    By BobL in forum METALWORK GENERAL
    Last Post: 24th May 2011, 01:16 AM
  4. Suggestion
    By NewLou in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 8th Jan 2005, 03:37 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
