Results 1 to 9 of 9
    Feb 2013
    Laidley, SE Qld
    967
    Default Little gizmos with 20 per side taper
    I'm making a heap of little gizmos on the lathe that have a 20 per side taper, 9 passes per item - cranking the compound with the little handles is going to get old quickly.
    Because the compound is set at 20 I have room to install a decent size handle for the duration of the job.
    May 2011
    Murray Bridge S Aust.
    69
    4,941
    Nice one Bob. I made a fairly simple taper turning attachment, that is micro adjustable. Can send you a copy if you like.
    Regards
    To grow old is mandatory, growing up is optional.
    Nov 2010
    Gippsland Victoria
    733
    Quote Originally Posted by KBs PensNmore View Post
    Regards
    Hey Kryn,
    I would be interested in seeing your taper jig please.
    Bill
    May 2011
    69
    4,941
    Hi Bob,
    Here it is
    Regards
    Nov 2010
    Gippsland Victoria
    733
    Hi Bob,
    Here it is
    Regards
    Kryn,
    Thanks for the photo.
    Am curious about the fine adjust - did you make a wormscrew onto some involute teeth at the end of the flat bit or is it a simpler mechanism ? ie a normal threaded bolt onto a matching (curved ?) threaded section in the end of the flat bar ?
    ........ and the other post that has just disappeared .... did you make your own collet chuck by setting up parallel to an ER collet ?
    Bill
    Last edited by steamingbill; 25th May 2016 at 10:34 AM. Reason: added er collett question
    May 2011
    69
    4,941
    Hi Bill,
    You're right, the fine adjustment is a piece of 6mm allthread, turned down to 5mm thread on one of the ends, and 5mm on the other to run in a hole as a support. The curved end was threaded using a 6mm tap. All the instructions are in the magazine for it. Can snail mail copies of it to anyone who would like one. Sorry dunno how to scan and email it.
    Yes the post that disappeared, I took off as it wasn't really relevant to this thread, was for making an ER25 collet chuck for my POS C2 mini lathe, I taper turned the inside then ground it with the Dremel flex shaft mounted in the toolholder. Turned out very nicely I thought. Did post it here somewhere.
    Aug 2008
    Tennant Creek, Aust
    59
    528
    I scanned the the copy that Kryn sent me , I can email it to you.
    Ratty 05/2004 -05/07/2010 COOPER 01/08/1998-31/01/2012
  8. #8
    Feb 2013
    Laidley, SE Qld
    967
    Regards
    Thanks for your kind offer. Your photos and the discussion following explain it all nicely, its a clever idea. I can see myself using it for single pointing tapered pipe threads.
  9. #9
    Aug 2008
    Tennant Creek, Aust
    59
    528
    Quote Originally Posted by bob ward View Post
    If you or any one else want the plans, let me know and I will email them to you.
  1. Taper Pins and taper pin reamers
    By tbonesmith in forum METALWORK GENERAL
    Last Post: 14th Apr 2014, 02:49 AM
  2. Anyone want to do a small job on the side?
    By browny in forum METALWORK GENERAL
    Last Post: 15th May 2008, 11:39 AM
