Results 1 to 6 of 6
    Oct 2019
    walllan, Australia
    58
    11
    Default slotted spanner?
    Anyone have a source for a set of the 'slotted spanner bits" for removing the slotted retaining nuts on the end of the ball crank handles (imperial 1/2", nut diameter, not thread size)
    A search of ebay comes up with 20,000 screwdriver bit hits LOL
    regards
    JD
    Sep 2012
    North Yorkshire UK
    3,920
    Hi Daggagh,
    Do you mean these
    If so I got mine with a set of security tool bits.
    Best Regards:
    Baron J.
    Oct 2004
    Southern Highlands NSW
    1,511
    Grind a gap into the end of a blade screwdriver?
    Jan 2004
    Mackay North Qld
    5,396
    Hi daggah
    With reference to BaronJ 's post. If your spanner /screwdriver is the same that he is talking about?
    Are you close to a Bunnings shop ?
    They have them ,albeit in a set of bits.
    There's at least one in the set and the remainder of the flat bits could be ground to custom sizes.For something larger you may well have to make your own .
    I think that using an unwanted bit from the set, an extra piece of steel-maybe from an old spanner (chrome vanadium) could be welded to it and then ground to size.
    There's always a way to do these things.
    The one I have comes in the set shown , see link below.
    https://www.bunnings.com.au/craftrig...t-set_p6320526
    Nov 2011
    Port Sephens NSW Southside
    94
    Hi Daggagh,
    Jaycar have this set cat: TD2035 $$16.95, Altronics Cat T2180 at Auburn have it for $13.95.
    JohnQ
    Jan 2004
    Mackay North Qld
    5,396
    Hi daggah,
    Would this be the type of slotted retaining nut that you refer to?
  1. Tee Slotted Cross Slide to suit Hercus Imperial Lathe 260/9".
    By pipeclay in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 2nd Jun 2018, 05:55 PM
  2. Hercus Tee slotted crosslide
    Last Post: 2nd May 2018, 10:58 PM
  3. Slotted plate Beaufort division DAP
    By zbm in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 5th Apr 2017, 08:28 AM
  4. hercus t-slotted crosslide
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 13th Mar 2017, 12:29 AM
  5. small steel round head slotted wood screws #2, #3, & #4
    By eskimo in forum METALWORK GENERAL
    Last Post: 26th Nov 2013, 09:08 PM
