Results 1 to 8 of 8
    May 2016
    Penrith
    6
    Default My 1966 Hercus 9in C
    Hi all,
    I inherited this Hercus lathe from my fishing buddy. I'm new to this, Mal Has helped a lot. Thanks Mal for all your help understanding all the parts. I will get my head around it one day. Lathe has a placard on it. DEPT NSW TAFE.
    Cheers Tommo
    Oct 2004
    Southern Highlands NSW
    1,960
    It looks nice, Tommo.
    Did you get the change gears too?
    You probably know already, but don't try to cut the shaft with that much supported overhang.
    My rule of thumb is 3x the diameter as a maximum length sticking out from the chuck, otherwise use the tailstock or steady for extra support.
    Jordan
    May 2016
    Penrith
    6
    Hi Jordan,
    That was only out for display, I was teaching myself how to dial in the 4 jaw chuck.
    Cheers Tommo
    May 2016
    Penrith
    6
    Jordan nothing extra as is, it's in pretty good nick for its age considering it started life at NSW TAFE.
    Thanks Tommo
    Jun 2007
    sydney ( st marys )
    65
    4,973
    We're setting zero at both ends or only one on your bar?
    May 2016
    Penrith
    6
    Close to the chuck, I watched some YouTube videos, Cracked on for 2 hours walked away watched another, had another shot done in 5 min. Now I find it a little bit easier.
    Cheers Tommo
    Jun 2007
    sydney ( st marys )
    65
    4,973
    When setting a long piece like that it needs to be set at both ends.
    It would be a very rare occasion when you can get the bar running true over that length without touching the out board end.
    In quite a few cases you would end up taping the out board end with a soft hammer to get it true, ( would pull the indicator plunger off the job when taping.)
    If the bar is not round ( may have a high spot ) then either 3 zeros are ok or 2 zeros and the other 2 readings can be the same ,EG 2 zeros and 2 .003" or something similar, if you try to get all zeros with a bar that is not round you will be chasing it forever.
  8. #8
    May 2011
    Murray Bridge S Aust.
    72
    6,281
    Welcome to a top Forum Tommo.
    To grow old is mandatory, growing up is optional.
  1. My 1966 Hercus 9in C
    By Ozymacca in forum THE HERCUS AREA
    Last Post: 7th May 2016, 08:10 AM
  2. Hercus 9" vs hercus 260 ????????
    By bitza500 in forum THE HERCUS AREA
    Last Post: 26th Jun 2009, 10:50 PM
  3. Hercus parts on Ebay from Hercus
    By bollie7 in forum THE HERCUS AREA
    Last Post: 8th Oct 2008, 02:59 PM
