Needs Pictures: 0
Picture(s) thanks: 0
Results 1 to 15 of 16
25th Nov 2014, 10:31 PM #1Diamond Member
- Join Date
- Feb 2013
- Location
- Laidley, SE Qld
- Posts
- 1,050
Halogen work light LED replacement bulbs
I've never had much success with bulb life with the halogen work lights that use the long skinny glass bulbs. Average bulb life for me has been somewhere between 5 and 10 nanoseconds.
Found these guys on ebay, one of many I'm sure, who sell replacement LED bulbs that are a direct replacement for the long skinny glass tube. This is one of their bulbs installed in one of my lights
http://www.ebay.com.au/itm/R7S-10W-L...tfrom=30637516
The really good thing about these bulbs apart from their robustness (you can actually move a light while it is switched on and the bulb does not fail) is that they are very low heat. This is a shot of me using an LED light as a temporary work light on my lathe, and it is brilliant, pun intended. There is no way you could use a halogen light in this manner, you would boil all the oil out of the headstock within 5 minutes. Not to mention severe operator discomfort.
26th Nov 2014, 05:41 AM #2Most Valued Member
- Join Date
- Sep 2011
- Location
- Ballarat
- Age
- 66
- Posts
- 3,172
What a great solution Bob,
I broke my last spare on the weekend, no doubt because I came within 10 metres of the stupid thing.
What colour/temperature did you get?
As an aside, how do you find the AL340D, I'm loving mine.
Phil
12th Dec 2014, 05:49 PM #3Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
I also have had the trouble of the bulb blowing when you come within one hundred metres of them, so bought a couple to try and they turned up today...
I had to modify my holder to get them to fit, but they now fit and work... I got the whiter light ones...Gold, the colour of choice for the discerning person.
12th Dec 2014, 09:38 PM #4Most Valued Member
- Join Date
- Sep 2011
- Location
- Ballarat
- Age
- 66
- Posts
- 3,172
Thanks Richard.
Phil
13th Dec 2014, 10:06 AM #5
Thanks ..... I have four of the single light versions sitting in the garage all with blown globes. I was going to toss them as the globes are too expensive, especially when they last a day or so. I will be sure to order a few of these led globes
If you don't talk to your cat about catnip ...... who will?
13th Dec 2014, 10:27 AM #6
This mob have many many LED bulbs and they do quick delivery as well.
I have got quite a few of their items.
If you want a good headlamp look for the cree 1800lm
This will light up the flea on a possum 50 metres up a tree on the other side of the road.
https://www.myled.com/p2760-zoom-led...500-black.html (this is only the 900lm)
Here are their list of R7S
https://www.myled.com/index.php?rout...rch&search=R7s
14th Dec 2014, 09:13 PM #7
Cool. I guess like many others there is at least one one of these lites with rs globes in ones shop.
Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
14th Dec 2014, 09:20 PM #8Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
The 10W LED bulbs and not as bright as the 500W halogen originals, but they are OK for close work and are cool, not hot..
18th Dec 2014, 06:23 PM #9
To achieve similar lumen output as a 500 watt tungsten globe you will need in excess of a 50 watt Led .
I replaced my old tungsten power sucker with the 50 watt Cree type led.
Its a softer white led but very clear and easy to see at night,very little glare when you look towards the light.
18th Dec 2014, 09:43 PM #10
One thing I do know is my 20 watt dedicated LED spot lite in the shed gets quite hot. So much so that the back case is a casting with cooling fins.
Lite output? comparable with the round spot lite it replaced.
Not the cheapest thing on the market, but after a few months, so far so good. Have no doubts it will be sturdier than the spot it replaced, and definitely a better bet than those useless halogen ones.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
21st Dec 2014, 06:57 PM #11
21st Dec 2014, 07:15 PM #12
27th Dec 2014, 08:13 AM #13Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
I wonder how something like this would go on a machine... it is low voltage at 12V
https://www.myled.com/p3488-led-floo...c12v,grey.htmlGold, the colour of choice for the discerning person.
27th Dec 2014, 09:03 AM #14Most Valued Member
- Join Date
- Jul 2006
- Location
- Athelstone, SA 5076
- Posts
- 4,276
I got a 880 lumen led downlight from Bunnings the other day...and to be honest compared to the halogen on the mill I am impressed.
I now just have to fit it tin place of the halogen...
I will get a picture and post a bit later
27th Dec 2014, 09:41 AM #15
I think it would light the machine up nicely. I am constantly looking for a suitable LED work light for my machines, but I think that the 10w version may be sufficient. It might be a bit big tho.
I just checked on the 10w version. It is smaller. 115mm X 85mm. At $9.55 + freight, it may even be possible.
Dean
24V work light halogen bulbs
By bob ward in forum METALWORK GENERALReplies: 13Last Post: 3rd Oct 2013, 11:42 AM
