Needs Pictures: 0
Picture(s) thanks: 0
Results 1 to 15 of 38
9th May 2014, 11:33 AM #1Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
Starrett 98/12 inches Vial replacement expert advice needed
guys.
any one here ever replace one of those ? i have a hard time try to find out how to undo the two side lock to remove the old broken one .
can any one help me on this ?
regards
peter
9th May 2014, 11:46 AM #2Most Valued Member
- Join Date
- Oct 2010
- Location
- melbourne, laverton
- Posts
- 1,910
level
hi pete. have you got a new vial. have you googled this
9th May 2014, 11:49 AM #3Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
9th May 2014, 11:59 AM #4Most Valued Member
- Join Date
- Oct 2010
- Location
- Posts
- 1,910
maybe
just a quess are those end caps on the tube threaded?
I know you did ask for expert help. hope my non expert guess
helps
aaron
9th May 2014, 12:16 PM #5Cba
- Join Date
- Aug 2007
- Location
- Melbourne
- Age
- 69
- Posts
- 1,410
You need to take the end caps off. These are most likely threaded, but I do not know your particular make. It could also be just push fit. The vial of this type of level is usually fixed inside the tube with a white putty. It is a similar stuff to what you use when jointing plasterboard. I think it is called "plaster of paris". The stuff will get soft in water, meaning you just soak the old barrel overnight in water, and next day you can push out a moist plug from the barrel containing the broken old glassware.
9th May 2014, 12:29 PM #6Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
Chris.
yes the end caps is exactly what i want to know how to undo them. when I try to twist the two end with two pliers on each side they don't seem to move but some pressure of the twist cause some more glass of the old Vial to broke at this point i stop .
cheers
Peter
9th May 2014, 12:45 PM #7Most Valued Member
- Join Date
- Oct 2010
- Location
- Posts
- 1,910
level
pete id put one end in the vise with soft jaws them twist with a spanner.
did you try some penetrating spray a little heat.
9th May 2014, 12:55 PM #8Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
9th May 2014, 03:40 PM #9
I have a Rabone 12" level (with a broken vial).
The end caps are push fit - there is some straight knurling on the plugs.
I also have a Starrett vial holder that I picked up at a garage sale a while back. It is about 4" overall length. Again, the ends are push-fit. Push-fit is about 1/2".
As CBA says, the actual vial is held in place by plaster-of-paris.
Care to share your source of vials?
Findlay.
9th May 2014, 04:06 PM #10Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
9th May 2014, 07:25 PM #11Banned
- Join Date
- Jul 2011
- Location
- Melbourne Australia
- Posts
- 1,376
I'm pretty sure I've seen a detailed write up on changing those vials on Practical Machinist. Including the putty that Chris mentioned. It would have been 2 - 3 years back. A search might turn some thing up. Me, I've never been a fan of those Starretts. All my levels are Euro.
Regards Phil.
9th May 2014, 09:26 PM #12Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
9th May 2014, 09:32 PM #13Most Valued Member
- Join Date
- Nov 2008
- Location
- North Brisbane. Qld. Australia
- Age
- 71
- Posts
- 1,620
Here's a PM topic with other links as well.
http://www.practicalmachinist.com/vb...repair-201873/
Nev.
9th May 2014, 10:53 PM #14Golden Member
- Join Date
- Aug 2011
- Location
- victoria
- Posts
- 499
10th May 2014, 05:09 AM #15Distracted Member
- Join Date
- May 2010
- Location
- Lower Lakes SA
- Age
- 59
- Posts
- 2,607
