Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 38
Thread: Starrett 98/12 inches Vial replacement expert advice needed
  1. #16
    Aug 2011
    victoria
    499
    Default some update on the process of restore this level
    the base will be send to Ewan to grind .
    Peter
  2. #17
    Aug 2010
    Near Bendigo, Victoria, AUS
    73
    3,156
    Grind??? What do mean, 'grind'???
    The base needs to be scraped - properly - to within a few micro inches or so and 40 points pre square inch bearing.....
    If you just want a ground one, buy a Chinese one
    Cheers, Joe
    retired - less energy, more time to contemplate projects and more shed time....
  3. #18
    Aug 2011
    victoria
    499
    Quote Originally Posted by jhovel View Post
    Thanks for your comment.
    I thought set it up on the surface grinder and clock it proberly will be just as good as it can get ? no ?
    Peter
  4. #19
    Aug 2010
    73
    3,156
    It's probably just fine - but I think precision tools should have the 'right' finish and 'look'....
    Cheers, Joe
  5. #20
    Aug 2007
    Melbourne
    69
    1,410
    Quote Originally Posted by thorens View Post
    Peter
    The level is probably going to be used on ground surfaces? If so I see no advantage in scraping the level.
    Also, I believe that standard Starrett model 98 "machinist" levels were not scraped from factory. The Starrett clone from Rabone that I have is not scraped either. It could be that the much more sensitive (and expensive) Starrett 199 "Master Precision" levels are/were scraped, I do not know?
  6. #21
    Aug 2011
    victoria
    499
    Quote Originally Posted by cba_melbourne View Post
    yes it will be used for lathe set up so i would say it will be used in a grounded surface . please see the picture of the base of my 98 level condition . it have some rust and when i clean the rust it leave some pitting so i thought send it to surface grinder to re-ground the base is a good idea . i don't know about the 199 model so i have no comment.
    regards
    Peter
  7. #22
    Oct 2010
    melbourne, laverton
    1,910
    Default grind or scrape
    I understand what joes saying but u think grinding would be a good start and maybe scraped at a later date.
    aaron
  8. #23
    Jul 2010
    Melbourne
    9,123
    Wouldnt that depend on the grinder? Both how the level is clamped and how good the grinder itself is?
    Which brings me to my point.... how you going to hold it Ewan?
    Stuart
  9. #24
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    No need to worry about the grinder.....It will hold .001mm over that size with ease.
    As for holding, without having the level in my hands it is a bit hard but am guessing that putting both ends in a vice would be the best, we shall see.
    Ew
  10. #25
    Jul 2010
    Melbourne
    9,123
    Quote Originally Posted by Ueee View Post
    Says who?(or what?)
    Now it may well grind parallel within 0.001mm but that's not flat*.
    Stuart
    *of course it might be that flat... but how would you know?
  11. #26
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Says the rock, my millimess and a holding meathod that does not stress the test piece at all.
    Ew
  12. #27
    Sep 2008
    Riddells Creek, Vic.
    899
    As this is not a high precision level there is no need for micron precision on the base. It really is not even suitable for setting up a lathe when trying to remove or introduce twist in the bed as the vial is calibrated to .005"/foot/division.
  13. #28
    Aug 2011
    victoria
    499
    Quote Originally Posted by Techo1 View Post
    Thanks.
    so what do you use those Starrett 98/12" level for ? you worry me now
    regards
    Peter
  14. #29
    Jun 2011
    Australia east coast
    72
    2,722
    Thanks.
    Rough carpentry. I should know, I've got a 6" Starrett.
    PDW
  15. #30
    May 2010
    Lower Lakes SA
    59
    2,607
    Thanks.
    regards
    Peter
    They're great for getting you within range of a finer level. 'Roughing in' if you like. The 98 series is described as a 'mechanic's level'. I think that word used to mean fitter/machinist. I guess they were considered ok for setting up run-of-the-mill machines doing ordinary work. Which probably means most of us here. The finer ones are needed for rebuilding work.
