My neighbour just picked up a bargain. It's a 3hp 4speed Waldown bench drill press. It's in pretty good condition. Great buy really. The spindle runs very true with no visible runout or noticeable play when you grab the chuck.
I have some questions though.
I'm guessing on all of these so be kind!
1: Is the top bearing packed with grease and the bottom bearing (I can't get to it) is oil lubed from the port at the top of the quill?
2: the bottom bearing just above the chuck feel like it has some grit in it, how do you strip it down to clean it? My neighbour slid out the pinion/handle out and the chuck and rack just slides out. I'm guessing the bottom bearing is a cup and loose bearing setup.
3: to remove the top bearing, I'm guessing you tap it out from below with a piece of pipe once you have stripped the rack/quill and the top collar with the three screws.
4: The original motor runs very nicely. Their is a screw in the back just below where the shaft breaks out to the pulley. It's got a lot of old grease around it. Is this a grease port for the motor bearing?
Thanks guys! It's a nice piece of kit and worth cleaning up! Is it worth replacing the bearings?
