Needs Pictures: 0
Picture(s) thanks: 0
Results 1 to 15 of 22
Thread: anything better then a dremel?
19th Jul 2013, 09:36 AM #1Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
Are there any small rotary tools out there better then a Dremel...
My third Dremel has just decided to let the magic smoke out and now it just runs slow and sparks, no the brushes are good...... These things are pathetic.. I do not use them that hard but they die so quickly.... My first one lasted a fair while... My second one about two months (but I lost the receipt of purchase ) and now it's replacement has died after a couple of years...
They are crap.... Need something better...Gold, the colour of choice for the discerning person.
19th Jul 2013, 09:49 AM #2
Foredom
I bought a Foredom from the US for about $250 when I had the same situation.
Much better machine and has variable sized colletts available. See it here, looks like the price is up a bit and postage is expensive. It wasn't available in Australia when I bought mine, but you might find it here now.
If you buy from states you need the 220V model and you can just get the plug changed.
Cheers, Ian"The common law of business balance prohibits paying a little and getting a lot.. it can't be done.
If you deal with the lowest bidder it is well to add something for the risk you run.
And if you do that, you will have enough to pay for something better"
19th Jul 2013, 10:34 AM #3Senior Member
- Join Date
- Jun 2013
- Location
- Tasmania
- Posts
- 261
Yep,
Get the Foredom. These are just night and day over the dinky over priced dremels. But they do come at a price. (i supposed the pertinent question is to ask what you want to use it for?)
They are available in Australia, I notice Carbatec is one source but there are several other online mobs that sell them cheaper too. We use one at work and it really is a solid unit, but we really don't ask much of it either, nothing that a dremel wouldn't do in out situation. But they are much better quality.
The foot speed control is handy too.
19th Jul 2013, 11:15 AM #4Most Valued Member
- Join Date
- Jun 2012
- Location
- SA
- Posts
- 1,653
Yes.
This is what I use. Pencil air die grinder - there is no contest.
Air micro die grinder
Rob
19th Jul 2013, 07:34 PM #5
Agree
Yes I agree. I have X 2 of these little tools and they are better than sliced bread . No overheating motor issues . I use one to sharpen the chainsaw teeth and also, those awkward jobs e.g., removing broken taps from small locations . The set of grinder bits that comes with the tool is not of much use . Buy a set of diamond tipped bits , cheap on ebay and the tool is so much more effective Mike BTW it sounds like a jet engine
19th Jul 2013, 07:46 PM #6Most Valued Member
- Join Date
- Jun 2012
- Location
- SA
- Posts
- 1,653
19th Jul 2013, 08:57 PM #7Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
thanks everyone.... Have bought an air one... The dremel is under warranty so will send it away as well..
19th Jul 2013, 09:08 PM #8
I agree with the previous posts wholeheartedly. I use and really like the micro air grinder. But I also got a small (Makita type) edge trimmer and have used the flexible shaft that came with my Dermel kit. That provides about the se speed as the Dremel but with power to spare.
JoeCheers, Joe
retired - less energy, more time to contemplate projects and more shed time....
19th Jul 2013, 11:54 PM #9Senior Member
- Join Date
- Oct 2008
- Location
- blackburn vic
- Posts
- 298
Better than a Dremel?
I have had a Scintilla (Bosch) die grinder for about 45 years. Really good piece of kit. Plenty of power, unstallable, and takes 1/4 shank tools. I got it originally to do porting and polishing on Cylinder heads. It has a suitable neck that I am going to make a TPG attachment for the lathe.
Roger
20th Jul 2013, 08:43 AM #10Senior Member
- Join Date
- Dec 2010
- Location
- Syd
- Posts
- 492
Suhner is generally considered the rolls royce of these sorts of tools, have both a big 20 odd lb version and something dremel size, other than brushes, they seem to go forever despite virtual daily use...seen a few on grays from time to time.
20th Jul 2013, 10:44 AM #11Senior Member
- Join Date
- Apr 2012
- Location
- Melbourne
- Age
- 58
- Posts
- 122
Used to buy Dremel but the quality seemed to be gone.
Tool wouldn't last very long.
now just buy Bunnings Warrior brand for $40 odd.
If they blow up, bin it and get another.
I seem to get at least three years out of each one.
26th Jul 2013, 05:26 PM #12Pink 10EE owner
- Join Date
- Aug 2008
- Location
- near Rockhampton
- Posts
- 6,241
My air one arrived today... It was the expensive one from CTC tools.... Turns out it is made in Taiwan... Quality seems to be superb...
MICRO AIR GRINDER - STRAIGHT HEAD #G69Gold, the colour of choice for the discerning person.
26th Jul 2013, 05:47 PM #13Most Valued Member
- Join Date
- Jun 2012
- Location
- SA
- Posts
- 1,653
Fancy 4 bearing model eh You lucky devil.
I only have the two bearing model and I couldn't tell you where it's made - probably China. Oil these each hour and they go forever.
The main thing to get the best results is to reduce the tool bit overhand/shaft length by making sure it goes well into the collet.
I actually ran a 1/8" drill through the spare collet (in the open position) and I find that will grip the 3 mm and 1/8 shafted cutters equally well.
Anyway, we expect a full report on how well it thrashes the pants off of your old Dremel.
Rob
26th Jul 2013, 07:15 PM #14
I have tried Dremels sometimes, but they are toys compared to my Minicraft MB1012.
It is the same size as a Dremel, but its 12V 100W motor is virtually indestructable.
I am using it for more than 25 years, and it is still going strong.
The high quality Rohm keyed chuck has a capacity of 0-6 mm, wich makes it a lot more versatile than the Dremel with its toy-chuck.
It is a shame, that Minicraft has disappeared from the market, but I have managed to buy two more of these drills second hand.
I bought them just in case my MB1012 would wear out.
Until now however, it is still going strong.
Would you believe I even drilled 6 mm holes in brick with it?
British made quality tools....
Cheers, Jan
26th Jul 2013, 07:35 PM #15Golden Member
- Join Date
- Aug 2012
- Location
- Australia
- Posts
- 645
Shinano (Japan) make a good air powered 3mm die grinder. At $271 the price is a few dremels or 5 CTC's..
Dremel help
By Dano48 in forum METALWORK GENERALReplies: 7Last Post: 4th Oct 2011, 12:13 AM
