Likes Likes:  0
Results 1 to 5 of 5
    Aug 2012
    Australia
    645
    Default Shaft diameter for circlip
    I am working on specifying some ball screws for one of my projects. At one end of the ball screw, I have a shaft that is 17mm. On this shaft I have a small bearing block. This bearing block is held in place (on one end) by a circlip which looks to have an inner diameter of 16mm (so a 1mm groove in the 17mm shaft). Ideally I want to use a circlip without reducing the 17mm shaft down prior to the circlip. I am thinking I can stretch the circlip with some circlip pliers and fit it over the shaft and wiggle down the shaft into place. That said, I am not 100% sure on this and do not want to have to re-purchase a replacement due to a silly mistake. Am I going to have all sorts of problems getting the circlip on the shaft if I do not reduce the diameter of the shaft prior to the circlip groove?
    Aug 2003
    Conder, ACT
    78
    2,803
    1/2mm deep groove.
    Should slide on ok.
    Aug 2012
    Australia
    645
    Quote Originally Posted by DavidG View Post
    1/2mm deep groove.
    Should slide on ok.
    Thanks for the help David. I will fix up the groove depth too.
    I can now finally say I am finished drawing these things!
    Jul 2012
    Griffith NSW
    435
    the roymech site has excellent info for things like this, i hit it up all the time.
    www.roymech.co.uk
    Nov 2008
    North Brisbane. Qld. Australia
    71
    1,620
    Circlips External
    Nev.
    Edit: Beaten to it while looking.
  1. minor diameter
    By tanii51 in forum THE HERCUS AREA
    Last Post: 26th May 2010, 10:55 PM
