Likes Likes:  0
Results 1 to 11 of 11
    Oct 2010
    melbourne, laverton
    1,910
    Default can you smell smoke?
    Unfortunately the vfd for my colchester failed.
    im having discussions with the supplier about a replacement.
    Attachment 220917Attachment 220918
    Apr 2012
    Qld
    44
    Nasty. What brand was it please? Can you identify the reason it failed?
    Regards, K.
    Oct 2010
    melbourne, laverton
    1,910
    hi k
    its a Huanyang about a year old. a 2.2kw one spinning a 1.5kw motor.
    i don't know what caused the melt down i was doing some light facing
    and it tripped the breaker.
    the next day. i reset the breaker turned it on and the drive smoked and then caught fire.
    The e bay seller replied quickly to my response and seemed very cooperative.
    Unfortunately his reply to my emails have slowed up.
    At first i thought he was going to seen a new drive. Its annoying because the lathe is out of action. ill have to move evry thing from around my hurcus.
    Jan 2004
    Bellingen
    278
    Sometimes electronics just meltdown! That's a bit rotten really. The 1yr warranty 'thing' always seemed a little short in my book. It comes across as if you get more than a years use out of that product your in luck.
    I remember when I built my belt grinder, I picked up a baldor vfd. The tec guys were very helpful and told me to match the kw of the vfd to the kw of the motor and not to step up to a bigger vfd. I was thinking the expensive electronics would last longer if not driven so hard. They changed my mind at the time.
    Baldor make some damn good gear and I cannot fault it as yet. I think it's about 3 hrs old now. The tec guys were really helpful.
    Jan 2004
    Bellingen
    278
    Just another thought, did you have it in an enclosure? I put an extra computer fan to pull cool air through a filter to keep mine running cooler.
    Aug 2009
    East Warburton, Vic
    357
    Quote Originally Posted by Ben Dono View Post
    I was going to ask this as well, because the first pic looks like it is mounted in a box etc.
    DJ
    Oct 2010
    melbourne, laverton
    1,910
    it was in the enclosure but i always run it with the door open.
    it wasn't hot and at the time it cought fir wasn't even spinning the motor.
    from what i understand the drive should be at least 1/3 bigger
    than the motor or even up to 3 times the rating of the motor.
    Its got a 2 year warranty.
    it was very cheap. . hopefully they will send a new one
    its just interesting that it caught fire.
  8. #8
    Jul 2006
    Athelstone, SA 5076
    4,276
    you let all the smoke out..thats what wrong with it
    1 year old...not good ...wonder if mine (also a Huanyang) will even work...when I get around to fitting it
  9. #9
    Jul 2006
    Athelstone, SA 5076
    4,276
    Quote Originally Posted by azzrock View Post
    maybe one of the capacitors overheated and caught fire???
    although and i just recalled a 10hp inverter drive airconditioner that I repaired a yr or so back...the inverter went up in smoke ..Cause.... a moth get caught inside and shorted out the PCB high voltage side ...thus also letting out all the smoke
    oh and the unit was inside the warranty period..... but warranty doesnt cover this sort of damage
  10. #10
    May 2012
    Perth
    4
    One of the problems with some cheap chinese electronics is poor quality parts or even counterfeits. A certain well known Australian electrical manufacturer was burned by this- the specified diodes or some other component were switched for a lower spec which was fine until many of them started to fail. This resulted in a mass replacement of thousands of devices that had been built, bought and installed in electrical installations. Some serious money was spent on fixing it.
  11. #11
    Oct 2010
    melbourne, laverton
    1,910
    i was happy with it . i just want a replacement. i haven't heard from them in over A week
