Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Jayco Camper Trailer ceiling replacement
    Aug 2012
    Perth
    7
    Smile Jayco Camper Trailer ceiling replacement
    Hello all,
    first post here so trust my post/queries are to the correct protocol.
    My 2004 Jayco Finch has developed a roof leak near the rear internal light and either another leak or condensation problem near the front light resulting in damage to the veneered roof sheeting. The 2004 model had the two part aluminium sheet roof with joint down the centre. We had found small mould spot near from light in April this year when camper sued for a 2 week trip which we cleaned up and thought to be condensation ( also some black mould on lower part of the metal door frame). Everything else was still good at that time. This is my third camper over about 20 years and never had leaks or other serious problems in that time.
    Water at front light may be from a leak at the rear as it has been parked up for a year with the front low and facing north so solar panels on roof are directed better towards the sun. Just moved into new house in June and camper now parked with rear to north and had the front slightly higher so water may have stayed near leak entry point.
    Deliberately left the camper up and level in heavy rain last night and some water on ceiling inside behind rear internal light but dry at the front light area – hence thoughts that front deterioration may be from condensation or water running down hill rather than roof leak at the front.
    I have been taking out a few of the internal roof mounted fitting each evening. With lights and curtains/valence removed, I can see some polystyrene foam in corners of the roof and at holes for cables to lights. Last night that work included the inner part of the skylight/vent hatch assembly. It has timber framing around the opening and low and behold, the 12 Vdc wiring to the rear light is looped in and out through that timber framing. Water wise at the hatch opening, the front and side timbers are dry but there was some water/dampness at the rear timber. No sign of rot in the timber so seems I have got in early enough. Getting more access and drying out the timber (maybe once dry also a coat of varnish to help seal timbers for future (did that on all seat and cupboard internal plywood and timber from day 1).
    In the past on various campers I have pulled back the aluminium sheeting on front face of roof and wall on first camper years ago to do some mods for pole carrier, did some minor wall mods for vents in second camper and wall rear mods to add AM/FM/CD stereo in current camper. I know earlier campers had timber roof frame and no insulation in roof so sheeting likely just glued to timber frame. By 2004 there was advertised to be “roof insulation” which may be polystyrene foam sheeting glued to metal roof with ceiling sheeting glued to foam (but then again 1991 models were claimed to have roof insulation but mine had no foam). Accordingly, as money is currently tight with recent purchase of new house, prefer to look at repairing myself . I am relatively handy at camper mods – have added larger water tank, 3-way tap and elect water pump, extra wiring and 12 Volt power outlets, added stereo system into rear wall, mods to internal cupboards, totally rebuilt front seat to gain more storage space, etc, for the current camper.
    Obviously first task is the find the source/location of the leak and reseal.
    In searching this and other forums seems Bunnings stock some Sikaflex adhesive sealant products (seems Sikaflex 222 has been recommended elsewhere) and also seems one must avoid silicone type sealants. Also found the name of the adhesive sealant used by Jayco themselves. So will purchase some suitable adhesive sealant rear to fix outer roof leak and then on the weekend look to removing the outer part of the roof hatch and roof centreline seal, clean up the parts and reseal.
    Then it will be down to how best to repair the now damaged (stained, bubbled paper coating near lights, and some mould spots on inside) ceiling sheeting. With most other items removed now, I can see staples at the sides and along (under the sheeting joint trims) the but the big question remains is there polystyrene foam in roof cavity (2004 model) and is the plywood glued to the foam.
    If glued, might warrant using some oil of cloves to “kill” any mound spores (apparently exit mould etc do not kill the spores) and partially sanding back (belt sander) the existing ceiling then glue and staple new sheets over existing.
    Still early days into investigations and repair however ,any advise/information/photos of Jayco Camper from members who know how the roof is assembled and how the internal ceiling sheeting is secured for mid 2000’s models greatly appreciated.
    Sep 2008
    Mount Richon
    16
    Hi Westaust55,
    I dont know if you are already a member or have even seen the site, but there is a forum called myswag.org. There is a lot of camping information on there, and a lot of Jayco users. Give it a try and see what that brings up
    regards
    Harmful81
    Nov 2006
    Bendigo Victoria
    81
    7,471
    I would wait with that until you remove the internal ceiling as water can travel a long way and it will be easier to follow the trail from inside.
    Yes, ceiling is glued to polysturene foam, with approx 19mm square timber battens runnin g along the ceiling sides and a few for dividers. There are also sheetmetal plates where there are light fixtures and where the fittings are to hold the door up in transit.
    I helped my son repair a 2000 model Swan, which had this repair done, new ceiling over old, by a previous owner and as a result they never really fixed the leak. We went up to the Flinders Ranges last October and it leaked. We finished removing both new and old ceiling and we were glad we did as it didn't smell too fresh inside that lot.
    We also used this opportunity to run some extra wiring for lighting and sound in new channels cut in the foam.
    Oct 2007
    Alexandra Vic
    70
    658
    If you are getting a leak through the roof skin, I would be removing all of the seam caulking on the roof and completely recaulking it. Had to do this every 4 or five years with an onsite van, even with no towing etc to weaken the caulking. This is the best way to keep moisture out of the ceiling cavity.
    Once you are sure that you have fixed the leak, start work on replacing the ceiling.
    Aug 2012
    Perth
    7
    Thumbs up Jayco camper roof leak and ceiling replacement
    Quote Originally Posted by Big Shed View Post
    Pulled out some staples tonight and carfully levered the plywood down along one edge to look inside to roof. I can now confirm there is polystyrene sheeting with the ceiling plywood glued to it.
    @Big Shed, any tips on the best way to remove the plywood and keep the foam intact?
    levering slowing has worked for a smaller area so far with a couple of mm layer of the foam remaining stuck to the back of the plywood.
    That seems like a good idea. I am having ideas on replacing the 16-Watt 2-D fluro type fitting I used to replace the Halogen lights with LED types now. Maybe use say 4 LED lights in place of the original 2 light fittings.
    Thanks for the feedback
    westy
    Aug 2012
    Perth
    7
    @Harmful81.
    thanks for that suggestion. will investigate the myswag forum as well.
    @malb,
    yes, I am considering to reseal all avenues for leak on the top side (ie around hatch and full length of centre line between the two aluminium roof sheets). No signs of water near the sides - seems to be on centre line near the two lights.
    Have started to remove the ceiling sheeting with a view to ascertaining more precicely where the leak was (which is something I can make a start on by lights in the evening - external roof is a daytime job). The fact that there is foam insulation will slow progress and best I can do is to look at the visible timber with plywood removed to get an idea on extent of water in roof space.
    Nov 2006
    Bendigo Victoria
    81
    7,471
    Use a broad scraper and slowly separate the plywood from the foam.
    No need to replace the existing lights, we replaced the existing globes in the original Jayco lights with LEDs from Ebay with the same fitting. They use less than 1/20th the power of the original globes, that's why we took the opportunity to put some extra lights in.
    As we bush camp a fair bit, power consumption is important when running off the 12 V battery.
    My son has a 2000 Swan and we have a 2003 Penguin.
  8. #8
    Aug 2012
    Perth
    7
    Thumbs up Jayco Camper ceiling replacement
    Thanks for that tip. I have some assorted width paint scrapers but will visit Bunnings for an extra wide version - I am sure I have seen some about 150 mm wide.
  9. #9
    Feb 2012
    Gold Coast
    14
    Quote Originally Posted by westaust55 View Post
    bar b que egg slicer they have a long handle might make it easier to get in behind the panel
  10. #10
    les88 Guest
    Classic Caravans - Newest Threads
    This is a site for caravan repairs and restorations, I am a member there and good advice on your problem
    les
  11. #11
    Aug 2012
    Perth
    7
    @Big Shed,
    another quick question: What adhesive did you use to glue the new plywood into place?
    @SirCol ,
    Thanks for the tip.
    Will consider the BBQ slice as an option if other wider scrapers are not reaily available with a longer handle.
    @Less88,
    Thanks. I will have a look at the Classic Caravans forum as well
  12. #12
    Nov 2006
    Bendigo Victoria
    81
    7,471
    SikaBond FoamFix
    Available from Bunnings, about $24 per can
    ...and before you ask
    http://www.gunnersens.com.au/product...y-plywood.html
    Available on special order, yes you guessed it, Bunnings.
  13. #13
    Aug 2012
    Perth
    7
    Thumbs up Jayco camper ceiling repair
    SikaBond FoamFix
    Paper and Polyester Overlay Plywood - Plywood - Building Products, MDF, Plywood & Benchtop Surface Materials - Gunnersens Australia
    Thanks Big Shed.
    Best to ascertain what others have used rather than take a punt based on what I might see on the shelf at Bunnings et al.
    Cannot see the SikaBond Foam Fix at Bunnings website but CSS website does give to outlets near me (Wangara and Osborne Park - only couple of km from me).
    Thanks for the link to the coated plywood as well. I knew Bunnings and Camec here in WA sell this item.
    Regards
    westy
  14. #14
    Nov 2006
    Bendigo Victoria
    81
    7,471
    You're lucky to find half of what Bunnings sell on their (woeful) website, but our local Bunnings stocks it (Bendigo-Vic) and at least 2 Bunnies in Adelaide (where son lives) stock it.
  15. #15
    Aug 2012
    Perth
    7
    Default Jayco Camper Trailer ceiling replacement
    A brief update for those who may be interested.
    I have now:
    1. stripped out the stained and mouldy ceiling plywood
    2. removed the roof hatch amongst other things found the metal upper lip that the seal mounts on has been bent inwards on the hinge side (likely since original install)
    3. removed all the old sealant on the roof from the centreline and side
    4. applied new Sikaflex 11FC adhesive seal to the roof joints and roof hatch
    5. flooded the roof with water and checked for leaks – all looking good
    Also have taken the opportunity to run some extra wires to enable fitting of some extra lights and have a fan fitted at the roof hatch.
    Next step will be to install the new plywood (already obtained) for the internal ceiling which I hope to do this coming Saturday using the previously suggested Sikabond foamfix. The original plywood has a paper coating whereas the plywood I have selected this time has a poyester film coating.
  1. Repairing Jayco Camper trailer
    By Calm in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 11th Mar 2010, 08:31 PM
  2. Camper Trailer Build
    By dazzler in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 19th Dec 2009, 06:00 PM
  3. New camper trailer
    By jatt in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 9th Sep 2008, 08:15 PM
  4. Camper Trailer WIP
    By Ticky in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 12th Apr 2008, 09:19 PM
