Likes Likes:  0
Results 1 to 6 of 6
    Nov 2008
    North Brisbane. Qld. Australia
    71
    1,620
    Default 12 Volt Portable Hydraulic Pump.
    Have a PE10 Series PR102 12 Volt Portable Hydraulic Pump for sale.
    This pump has never been used and in as new condition.
    Selling now for well below replacement cost.
    $750.00 plus postage.
    Pickup available from Kallangur on northside of Brisbane.
    Item # PR102, Electric/Battery Pump Hydraulic PE10 Series Upto 25 Ton Quarter Horse on Metro Hydraulic
    http://www.excel.com.au/verve/_resou...tery_Pumps.pdf
    Nev
    Nov 2008
    71
    1,620
    Reduced to $650.00 plus postage.
    Nev
    Nov 2008
    71
    1,620
    Reduced to $550.00 including postage.
    Nev
    Nov 2008
    71
    1,620
    Thought I would give the pump the once over so I was sure everything was ok with it. I suspected something was loose inside the case. When I opened it up I found that the strap that holds the pump motor to the case was a bit loose and the rubber cushioning between motor and case was floating around inside. This has now been fixed with a new strap made from a strip of thick aluminium flat shaped to fit the motor and mounting points in the case. The original was very thin perforated steel strip and I suspect, stretched a bit over time. Also replaced the rubber cushioning between case and motor with a piece of thick rubber hose, split and fitted to the curve of the case where the motor is clamped in. I have also added threaded inserts to the base and fitted rubber feet to it. These can be removed if needed allowing the pump to be mounted in a fixed location. There was also a little piece or two broken away from where the oil filler flange locates inside the case so I installed two small screws through the case to lock this in place and to stop it rotating when the filler plug is removed or refitted.
    Nev
    Nov 2008
    71
    1,620
    My batteries in my 4WD just died on me so I am now a bit desperate and willing to let this go for the price of replacing the batteries. $400.00 plus transport cost. That should be around $50 if I send it through Smart Send. So $450.00 is now the price. Anyone want a bargain?
    Nev
    Nov 2008
    71
    1,620
    Advertised elsewhere. Please close.
    Nev.
  1. Hydraulic ram
    By GSRocket in forum METALWORK GENERAL
    Last Post: 6th Oct 2012, 10:19 AM
  2. Hydraulic Log Splitter
    By Geoff Dean in forum METALWORK GENERAL
    Last Post: 15th Apr 2008, 12:01 AM
