Likes Likes:  0
Results 1 to 7 of 7
    Apr 2008
    Canberra
    805
    Default What type of oil can do I need
    My lathe has oil nipples that look like the attached photo. What sort of oil gun do I need for these? The ball bearing in the centre is spring loaded.
    Oct 2008
    Leopold, Victoria
    66
    18
    I believe you need an oil pump type gun like this. They come with a pointy or radiused nozzle which will fit into your oil nipples. Should be available from the major lubrication equipment suppliers in Australia.
    May 2010
    Lower Lakes SA
    59
    2,607
    I think we just had this conversation:
    spring loaded oilers
    Apr 2008
    Canberra
    805
    Strewth...im not sure how I missed that post!
    Cheers fellas
    Aug 2008
    near Rockhampton
    6,241
    I just use a bog standard oil can..... Point the nozzle into the ball and pump away...
    Aug 2008
    Adelaide
    69
    1,395
    Quote Originally Posted by 19brendan81 View Post
    Cheers fellas
    Don't feel too bad - this topic pops up every year or so.
    Jun 2006
    Armidale
    60
    155
    I just use a 10ml syringe and a blunt 18g needle. I can push the needle just pass the ball and squirt oil behind it .The only problem is is winter when the oil is cold it it harder to squeeze out of the syringe.
    Terry B
    Armidale
    The most ineffective workers will be systematically moved to the place where they can do the least damage - management.
    --The Dilbert Principle
