Hello all
Does anyone know what grade or weight of oil to use in a Lathe gearbox.
Hello all
At work, depending on the machines speeds we used Shell Tonna 46 or 68, really slow rpm, heavy load boxes used 220! Here is a Shell PDF
My enquires on this subject lead to a hydraulic oil ,like Tellius 46. Hydraulic oil, I am told, does not keep metal particles suspended in the oil so they do not damage any of your gears.
D D
Unfortunately hydraulic oil usually comes in 20 ltr or larger drums.
I have an older Taiwanese lathe which tends to leak somewhat. An engineer suggested that I change the original heavy to automatic trans oil. This allowed me to use top speed comfortably; but leaked like a mongrel.
I recently drained what was left and replaced it with compressor oil which is a bit heavier. Works like a charm and doesn't leak as much.
The compressor oil was recommended on an engineering forum.
Toggy.
A 15 to 20W non detergent oil.
I used the Castrol version, Hy Spin I think its called. Available in 5L bottles.
Seems to work ok
Thanks everyone for the info, just have to decide which to use now, I already have a 20 litre drum of Tellus 46 in the back shed used to refill the tank on the Kevrek crane mounted on the back of my ute, I thought that might be a bit light to use as the oil in the lathe is of a heavier grade. The lathe is Chinese built, 240v with 9 speeds.
Once again thanks for the info.
Dermott
I dredged up this old thread because my brother gave me some advice on this subject last night.
He uses Mobil 1 synthetic in his machines. My brother has been in the machining game for thirty five years, so I guess he has some knowledge on the subject. Anyway.... I am intending to switch to synthetic. I will report back if it doesn't go so well.
Yeah, I used this in my modern Trumpy; good stuff.
Might be a bit of overkill in a stationery engine tho.
