Homemade motor oil/cutting water
anti corrosion oil, simply put is oil that has sulfur in it, the sulfur reacts with the oxygen in the air and prevents your steel from reacting instead with the air
its done super simple by just heating up basic oil with sulfur, since regular oil does contain some acid groups you may wanna use mineral (paraffin) oil, i believe this can be bought as "baby oil"
once its done you will notice the oil having turned a slight bit yellow, and as a bonus you may get some neat sulfur crystals
i dont know any particular measures for how much or how little sulfur you add to it
now you have basic engine oil, i wouldnt advise anyone to dump this in their car since theres probably some specifications for the oil they manufacture that makes it run extra well- it may work for hydraulic oil- and our next step
making saw "water"
you mix up the oil with water and add soap and blend it up until it doesnt seperate anymore, shaking it up in a plastic bottle will do really.
edit: totally forgot photo of the nice flaky sulfur crystals that remained once the oil cooled back down
https://gyazo.com/cf3ac7a64d62dfa7c40b04e4b8974645.jpg
