Originally Posted by
shedhappens
steve you can weld a few metals with a stainless rod, whether they stay welded is the question though....
The pro's would probably say no......but I am not a pro welder so that means that I can weld cast iron with stainless rods and have done a number of times, mostly successfully, sometimes not, depends on the cast iron.
I use 316L stainless rods, yes you can weld cast iron, steel to cast iron, high speed steel to mild steel, but you can only do this if you are not a Pro welder :D
