Is it easily possible to get a smooth surface finish when casting aluminium?
Is it as simple as using fine sand. I need to make sinker mould and want the finish of the lead to be reasonable smooth.
It's basically the sand. For a fine finish you may even have to got to plaster (but well dried). Another alternative might be a split Al mould, similar to that used for blackpowder shot/ bullets.
When they cleaned out the water jet cutter tank at work I took some of the fine, used garnet home and dried it out, I haven't cast anything with it yet but you can imagine how fine it is after going through the water jet, I'm not sure if the % of metallic particles will have any affect on the casting, they may impregnate the outer layer but I doubt that will matter for me. got any shops with a water jet near you?:2tsup:
A couple of years ago I was in QLD and my mate's mate was using some form of silicone to cast lead sinkers
How smooth do sinkers need to be If you want high finish like bullet moulds they are machined in Aluminium on a mill, sand finish would be Petrabond for a really fine finish you could use Delft Clay but that is pricey ( and hard to get at the moment). Mt mate uses a Douglass type setter I don't know ho he makes his moulds I can ask him after the 11th when he comes back to civilisation.
The plaster needs to be well dried so that there is no water to flash to steam. Probably some time in the kitchen oven would do it.
What shape are the sinkers? It may be just as easy to machine a cavity directly into the Al block. I'm off until the 11th, so could help if needed.
sinker shape is akin to a bullet eg 20mm round with a flat bottom then about 1/2 along tapers to a point...or small length round bar with a solid cone on one end
Attachment 390218
Attachment 390219
the round solids fit into the mould to adjust weight. My intention is to make the moulds so that spaces are not needed.
I have a 60 degree included angle countersink that is 19.5mm in diameter. I think you would want to pour into the base of the sinker rather than the top (potential to freeze off too quickly), so an open top mould would probably do it. Have a think, let me know...
I was thinking something like this -
Attachment 390224
The countersink would not mill the material out as such. I'd drill most of it out and use the countersink just to clean up. The wire would go in when the mould halves were fastened together. There might be a little bit of leakage around the wire but if the mould was resting on a sand tray, it would not be much. For wire, I'd just use a bit of stainless welding wire twisted up (I have 0.9 or 1.6 if the fish are really big...). The sketch is a bit dodgy - there should be less distance between the bottom of the mould and the bottom of the cavity.
It could be moulded the other way up but the mould gets more complicated with how to get the metal in and the part out. This way you can make the body a little longer and clean up the base in the lathe if needed.
if you look closely at one of the pics I posted you will see a metal thread (spot welded to wire) which allows for a plastic tip to be screwed onto the base of sinker....this of course must be cetrally located.
this pic should explain
Attachment 390249
