Sheraton 9A #1167 was purchased in 2007 and operated successfully for a couple of years.
I read all the books and diligently kept a good supply of oil up to the headstock bearings.
I taught myself machining on this lathe, corrected several problems and was getting good results.
Then, it developed hot headstock bearings and the occasional seizing.
An inspection revealed bad bearing surfaces with significant scouring and quantities of loose debris.
The spindle runs directly in the CI housing, with helical grooves in the housing to distribute the oil.
I formed the opinion that the debris had been flushed out by the oiling and was moving into jam-up positions.
There was the prospect of significant difficult work to correct, so a replacement lathe was purchased.
I enrolled in a TAFE course and eventually was able to use the cylindrical grinder and horizontal borer.
The spindle was ground, the headstock bored out, bronze liner glue fitted and bored to suit the new spindle size.
Then I got kicked out of TAFE !
Years have passed, but now has come the time to get the old girl going again.
The photo shows the headstock after slitting with a gap now of 2 mm.
Measuring the chuck end, bore is 45.76 mm and spindle is 45.73 mm.
They won't go together easily, and I have not tried to force it.
Attachment 389027
Requesting comments on a couple of subjects:
- what bore size should I have,
- how to go about lapping the bores,
- size of hole to drill through the bronze for the oil,
- source for suitable oilers (I think 5/16" BSF),
- advice on grooves in the bronze to distribute the oil.
Keep well,
John.
