17 Attachment(s)
More "This shed is getting a bit full"
Yes, those immortal words have been uttered as the other half is looking for something...
To show willing (and move some change of mind projects), I present the following -
A couple of brass leadscrew nuts from the US, NIB. $30 each (note that one is LH thread)
Attachment 387862 Attachment 387863
A drill sharpener, with instructions. I used to use this but now have the Darex :) $25
Attachment 387864 Attachment 387865
A set of 4 BIG 32 series collets (8, 10, 20 and 25mm). I doubt anyone here would use them, but before they are binned... $20
Attachment 387866 Attachment 387867
Mitutoyo 2 to 3" micrometer $40. Fowler clock (graduated in 0.001") $30
Attachment 387861 Attachment 387860
JT1 to straight shank (1/2") drill arbor. $20. Electric level. Works, but no battery $20
Attachment 387858 Attachment 387859
1/2 hp 3 Phase motor (6 pole = 900rpm nominal) and VFD $200 - could separate I suppose if needed. 1:100 gear box $100
Attachment 387869 Attachment 387868 Attachment 387870 Attachment 387871
Scleroscope - early hardness tester. I even bought a new rubber bulb for it (works on air). Probably not practical in a workshop but cool clutter for a man cave... ($75)
Attachment 387874
One of those "I can't get this thing to work" gadgets. It is meant to grind TIG electrodes to a nice taper but I think I did not have the pressure right to get it to rotate. I'm now making up a device to fit on a bench grinder, so it is not needed. ($20)
Attachment 387873
Old knuckle press. I was going to turn this into a sheet metal notcher, but then found one on Gumtree:U. Complete except for the handle. At a guess, I'd say around 2t? Ram is adjustable but stroke is limited, so not too good for bearings, but to set rivets or stamp things would be good. $250
Attachment 387872
Any freight at buyer's expense.
