3 Attachment(s)
Sheraton 'C' lathe rebuild.
Well, a week or so ago, I managed to remove the chuck backplate that was stuck fast & would not loosen with a rattle gun previously applied when the chuck was still attached.
Taking the idea from the American South Bend web site I made a split clamp for the l/h end of the headstock shaft from 20mm alloy stock & used a piece of steel plate suitably drilled to secure the r/h (backplate) end. Two 400 - 500mm lengths of 25mm rhs for leverage & pull hard... when that didn't work, pull VERY HARD. I was looking for an extension bar when... Man, that was a TIGHT bugger...
I was interested to see that the thinners/atf oil mix that I had applied a week earlier had migrated right down the threads; but of course it was the friction of the rear surface of the backplate against the corresponding shoulder of the headstock spindle that was the real problem. No damage evident on the male or female threads.
Pictures as below...
Attachment 387737Attachment 387736Attachment 387738
I have the headstock all in pieces now for inspection.
The stand & lathe bed are all finished & re-attached to one another. More photos to come.
