Help with Lagun/Pacific FU-2 Mill
Hi all,
I have a new-to-me Pacific FU-2 (which I believe is the same as a Lagun FU-2).
I had it running for a few test cuts but after a while it gave up the ghost. It slowed down while I was moving the table and now it's a brick. The table won't move, the spindle won't turn and the pump won't pump.
A friend who knows his way around this stuff much better than me came over and had a look and confirmed that I'm not bumped up against any stops or anything like that. He also brought a multimeter and did enough poking around to think it's an issue with the control circuit. His hunch is that the stop button is being constantly triggered.
This is where I need some help. I haven't been able to find a manual (the machine is different to the FU-2 LA, which I think i saw a manual for) and he wasn't sure what voltages to expect across the breakers if his hunch is correct.
Does anyone on here have a manual or a schematic they could share? Alternatively, does anyone have an FU-2 they could test the voltages on while the stop button is pressed?
Thanks for reading!
Tris.
