Originally Posted by
OxxAndBert
Out of interest, did the fork bend at the joint, or on either the horizontal or vertical straight section?
The extension tynes/slippers they have at work are about 6mm thick, and fabricated from an upside down C section with flat welded across the open side (the bottom when in use). Not sure of the material but likely some alloy steel as it looks and machines like that.
I've got the remains of one here that was scrapped after one of the forkies managed to jam a lump of pallet timber up inside that couldn't be extracted :(
Only mentioning the construction method as it allows for different thickness top and bottom, albeit with a bit more welding required. Also allows easy access to the inside of the section prior to welding up the open side if you wanted to add additional material at a stress point.
More design thought and fabrication, but stronger product for same or less weight.
I'm pretty sure Duragal is 450Mpa so that might be a reasonable option if you did need something slightly stronger in the future - without going to full on 4130 etc.
Damn nice job you've done with those ones though!!
