Quote:
I will try to find it on you tube an idea around using a plastic zip lock bag to keep them clean,
But I can’t remember all the details.
Just drop it into the Bag and zip it, that's all there is to it. That is also a handy way of picking up small nails, bolts nuts etc, when you drop the container on the floor. Have the magnet inside the bag, pick up "whatever", then turn the bag inside out with the magnet now outside, take it away and the "whatever" falls onto a bench or your V tray. I made a V tray from some thin sheet metal, with the sides bent up about 25mm and the bottom of the V narrow enough that it fits into the container that I dropped, usually use the peanut paste plastic jars.
