2 Attachment(s)
The quest for the holy grail...
So like most of you, I have a workshop space that is far too small for the amount of stuff I have. The astute amongst you will have noticed I’ve been thinning the herd a little over recent months and some of you now have some nice olde worlds machines adorning your workshops. Now that I can actually walk through the centre of the garage without tripping over a Herbert quill assembly or a Frejoth lathe bed it’s time to turn my attention to getting some sense of organisation into what currently remains...
I currently have around 28sqm to play in and have been consolidating the contents of two other larger sheds at other properties down into that space. It’s been kind of liberating to let go of some stuff but also challenging because there’s just so much of it. I imagine it’s a fairly common theme that most of you understand, so in order to keep myself honest and keep progress in a forward direction and maybe give those of you playing along at home something to amuse yourselves with I thought it might be an interesting process to document my quest for the holy grail of workshops... ORGANISATION!!!
Chapter 1..
The Great Wall.
Today I had a few hours reprieve from the dreaded ‘honey do’ list, which currently has me banishing the 80’s from out lounge room and building out the floor in the lounge room to the same level as everything else around it.. So how did I use this utopian slot of time? Well I now have order amongst the largest portion of my work holding devices. I finished up the last piece of the clamp rack in the form of the vice grip bracket and now have all things clamp in one tidy place. As a result, I now have four less milk crates on the floor... yes you read that correctly..
5 Attachment(s)
More progress to report..
So the lounge room now has a big tick next to it on the list with the exception of the skirting, that has a lead time because the red and green don’t keep the profile I need in the timber I want so I’ve had to order it from a specialist supplier. This earned me some workshop time :U
After hanging the first cabinet and stuffing it full of things temporarily to get them out of my way, I decided the next logical step was to shift the material that was on the unistrut between the wall of clamp and the cabinet to make way for more cabinets. I could have just moved a couple of ready made cantilever arms over and been done with it in a few minutes but when I tried it didn’t really work for me because of the bulk of the cantilevers and the encroachment into the space where I was intending to put them. I saw a statement somewhere that said when you have a welder everything becomes a bracket.. I sectioned a piece of 50mm square SHS and used up some small pieces of 25mm square to make some less intrusive cantilevers.
Attachment 384485
Not entirely happy with end result because I had to put Copco straps on the top as a measure of safety because I didn’t like how all the material sat. Most likely revisit this at some point, or put some safety chains on it like at the workshop of a previous employer.
Attachment 384486
I also short changed myself on the length, I didn’t account for the conduit on the pillar on the right. Is what it is.
So I’ve now stripped all the cantilevers off the other wall and need to procure more angle and ally sheet to put up more cabinets. That may have to wait a bit because I have no means of transporting a 4m length of angle. The steel supplier I use will only load 3.6 onto my trailer before it’s at legal overhang (the solution is coming).
In my shorter blocks of time I try to keep the sense of accomplishment up by getting a smaller job done. Since the last update I’ve ticked some of these.
The first one was creating a place for the spirit levels to live that’s not the corner of the lounge room now it’s finished. Some off cuts of 75x50 cut down further and a couple of scraps of flat bar et voila!!
Attachment 384487
The second was dispensing of the cords on some more of the AC powered tools. This may not be for everyone but for me it’s a winner. I really don’t like trying to manage cords on power tools so I fit much shorter IEC leads (kettle plugs to most people) to them and then only have to manage a couple of kettle leads.
Attachment 384488
Lastly, I made a small plastic holder for my centre punch collection in the top drawer of my tool box. Didn’t quite have the hang of the speed/feed for the cutting board it’s made of so I had to trim the whiskers that cut and re-melted themselves with a Stanley knife blade.
Happy enough with it to say I’ll probably make more for other things.
Attachment 384489
If you’re still awake.. that’s where it’s at at the moment
