Hi, first post on this site hope its good. during strip down of apron wicking felt got pulled out. not sure now where it goes or how to fit it. can anyone help?
B Brooker
B Brooker
Just in case it helps, for the very similar South Bend 9 inch lathe:
https://www.amazon.com/Guide-Renovat.../dp/1482364883
US dollars I think.
Also:
https://www.amazon.com/South-Bend-La...TT2CCAHQ5YDF2N
Also: I've heard of using a shoelace as the felt in the apron.
Hi Guys,
FWIW felt carpet underlay works well as an oil wick !
Here's a cautionary tale of a Hercus lathe purchase and subsequent rebuild. There's some apron details.
http://www.lathes.co.uk/hercusapron/...cus/index.html
Hi, thanks for the stripdown of the hercus9 apron. Looks like that wick goes from the little oil sump up through the casting into the bottom of the worm bearing. Is that right? If so I guess I have to pull the worm out to fit the wick? It looks like there is a bit of wick lying in the bottom of the bearing too? Think I'll pull the worm.
Cheers and thanks for the help.
Brian B
Long time since I did it, forget details but I think that's right - dismantle the worm drive assembly for access.
Hi, found the hole in the casting and fitted the wick,home made from 3mm felt. Hope the oil will rise to the pinion bearing. Will add pic of my finished recon 9" if possible. Thanks for all help.Attachment 383603
Hi Brookerbj,
Very nice looking lathe, I'd be very proud of that !
