Setting Up A Jewellery Workshop In A Secondary School
I have been asked if to setup a Jewellery workshop in a secondary school. Making things like rings, necklaces and raise vessels. I did a sub major in Gold & Silver Smithing at uni but I have never setup a workshop or purchased tools for the craft. I have taught the subject at another school as a CRT but again I did not setup or run that workshop either. I was wondering if anyone could recommend a reputable on stop shop were I could purchase most of the following in Australia. It cannot be eBay or international as the school needs invoices and ABN's.
I have found a few online shops but the all have only some tools but not everything.
Also were do people get their sheet material from?
If anyone can recommend other tools that I might find useful.
Heat Resistant Soldering Fire Bricks (enough to cover just over 1 meter square of space)
Jewellers Piercings saws frames (x15)
Saw blades set of 12 Size 1/0 (x5)
Round Nose Pliers (x4)
Chain Nose Pliers (x4)
Soldering Tweezers - Curved (x2)
Soldering Tweezers - Straight (x2)
Third Hand with Round base (x2)
Chasing Hammer (x4)
Small Rectangular Raising Hammer (x4)
100mm Dividers (x4)
Wooden handled three sided scraper (x2)
Vernier (x1)
Ring Mandrel (x2)
Ring Sizer (x1)
Flint Lighter (x3)
Solder Picks (x3)
NOT STRICTLY JEWELLERY RELATED
Compresser hose nozzle (x1)
Metal Dust Pans & Brushes (x6)
Hoses and fittings for three LPG gas torches (We have the torches)
Selection of different torch nozzles for annealing and soldering (3)
45kg LPG tank & regulator
Linisher attachment for the bench grinder with suitable selection of very fine grit belts
Bench grinder stand
Rust Inhibitor
MATERIALS
- 0.8mm copper sheet
- 0.8mm brass sheet
- 0.8mm nickel silver
- Silver solder (Can anyone recommend an easy solder general purpose solder brand)
- Flux (Can anyone recommend an easy solder general purpose flux brand)
