Results 1 to 5 of 5
Thread: Sheraton Lathe
26th Apr 2009, 09:51 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
Sheraton Lathe
Hi,
A first post from a new member of the forum.
My 9 inch Sheraton Model A appears to be a clone of South Bend and Hercus.
Unsure of the history, but it has had a hard life and is in need of some repairs.
Anyone else out there operating a Sheraton ?
Am I able to post inside the Hercus Forum as various parts appear, at face value, to be inter-changeable ?
Worst problem is the headstock bearing - TIR of 0.003 inch and noticeably rough finish on the spindle bearing surface when inspected through the shim slot.
The spindle appears to run directly in the headstock housing (no bearing liner).
I have convinced myself that the bad bearing contributes to the poor finish on 1020 grade steel using HSS tools.
Free machining steel like 12L14 is no problem.
Any advice on pulling the spindle for a complete inspection ?
Happy machining,
John.
26th Apr 2009, 10:53 PM #2Intermediate Member
- Sep 2007
- 29
My Father in Law has one of those lathes and I have seen him use it (works very well)... was bought from a tech School when the Govt in Victoria closed them all down a few years back.
Sorry can't help you with anything but I at least know what you are talking about.
Chipman
27th Apr 2009, 11:06 AM #3Senior Member
- Canberra
- 184
I'm sure you'd be made more than welcome in the Hercus forum John.
Check out this document on adjusting the bearings
http://www.wswells.com/data/howto/Sp..._Adj_9_10k.pdf
8th Jul 2009, 01:00 PM #4New Member
- Jul 2009
- Kareela, NSW
- 3
Sheraton Lathe
Hello John,
I bought some lathe parts last year that could be Sheraton. I have not been able to find a similar lathe to compare it with but it looks quite like some photos of a Sheraton on the lathes.UK website. All the parts are new and some have not been finish machined. I intend to put together an entire lathe as I got most of the bits and have been aquiring the missing parts since. If there are any small parts you need I may be able to help.
Glenn
9th Jul 2009, 11:38 AM #5Golden Member
- Apr 2009
- Kingswood
- 930
Glenn,
Thanks for the comments, I have sent you a PM.
Happy machining, John.
Cheap Sheraton on Ebay
By nexusone in forum METALWORK GENERALReplies: 0Last Post: 16th Nov 2008, 07:02 PM -
sheraton or hercus owners I need help
By matthew_g in forum THE HERCUS AREAReplies: 1Last Post: 24th Aug 2008, 10:06 PM -
Sheraton Lathe information?
By Greg Q in forum METALWORK GENERALReplies: 18Last Post: 25th Jun 2008, 09:36 PM -
Multiple Sheraton Lathes
By nexusone in forum METALWORK GENERALReplies: 1Last Post: 8th Mar 2008, 06:01 PM -
Sheraton SSS lathes
By Aussie redback in forum METALWORK GENERALReplies: 5Last Post: 5th Jul 2005, 02:41 PM
