Results 1 to 9 of 9
Thread: Cutting stainless steel welds
14th Mar 2009, 04:59 PM #1Golden Member
- home
- 621
I have a couple of stainless steel work trolleys that I picked up at the same time as my chairs.
The stands were originally used to hold computer work stations and the top has a slopping front and a plate onto which the LCD monitor was mounted. It's this plate I want to remove.
The first picture shows the whole stand and the second one shows the monitor brace that I want to remove.
The brace is 4mm SS and is welded to the top and back bracket (hope it's clear on pic3). The weld is not along the entire length of the plate, just at 3 or 4 places along it, same for the weld on the back bracket.
What's the best way to remove this plate? I'd like to keep it in one piece if possible -- might come in handy for something, but it's the trolley top I really want to keep intact.
I can post more picture if it make it any clearer.Geoff
The view from home
14th Mar 2009, 05:06 PM #2
Geoff I would have normal said a 1mm cutting disk but looking at access
If you have a Dremel it may be the way to go with a small cutting disk or a pointed Bur remover
14th Mar 2009, 05:14 PM #3Golden Member
- home
- 621
Hi Ray,
Yeah I tried a dremel but there's just not enough access for a cutting wheel.
Might have to walk up to Bunnings and take a look around (when it stops raining)
[How are the draughtmans chairs working out?]Geoff
The view from home
14th Mar 2009, 05:15 PM #4
Use a thin cutting disc at the one side you can get at and then you should be able to flex the plate back and forth a couple of times and the TIG weld should break fairly easy as it doesn't look to have penetrated much
DJ
ADMIN
14th Mar 2009, 05:28 PM #5
Bummer then a Carbide or Diamond Bur remover won't get in there either
or would a pointed one
14th Mar 2009, 05:31 PM #6
Have you got an old or cheap chisel laying about? A few good hard whacks with a hammer should break those welds.
DJ
ADMIN
14th Mar 2009, 05:36 PM #7
14th Mar 2009, 05:54 PM #8Golden Member
- home
- 621
DJ - A big hammer and not so sharp chisel did the trick. This broke the weld on the lower joint and bending the plate back and forth a few times took care of the other welds.
No damage to either bit of metal - the chisel on the other hand...Geoff
The view from home
14th Mar 2009, 06:58 PM #9
Cutting stainless steel pipe
By ratchet in forum METALWORK GENERALReplies: 13Last Post: 21st Sep 2009, 09:51 PM -
Stainless steel hex bar
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 21st Feb 2008, 11:28 PM -
Cutting Stainless Steel
By Mickj in forum METALWORK GENERALReplies: 9Last Post: 12th Dec 2007, 05:42 PM
