Results 1 to 9 of 9
Thread: Tool and cutter grinder plans.
27th Feb 2009, 07:36 PM #1Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI Everyone, I have found a Website with Plans for a Tool and Cutter Grinder for free that I want to share with You all. I recently received a CD on Tool & Cutter Grinders. The CD, I bought on Ebay of Seller 'Marypoppinsbag' which is also www.metoolsonline.com based in the UK. The CD has got numerous Tool and Cutter Grinder Manuals and info as well as a set of Original Plans for a 'Bonelle Tool and Cutter Grinder'. The CD only cost with Postage 9.50 British Pounds well worth it.
Anyway the other Night I was looking on the Internet to try and find out what size Motor it needs. When I stumbled upon a Website with a Revised set of Plans in PDF form for the 'Bonell Tool and Cutter Grinder'. The Plans are free to Download. Whilst searching the Internet for Info on the 'Bonnell' one or two sites were saying it is better than the 'Quorn'
The Website Link is http://homepage.ntlworld.com/j.b.d.w...20drawings.pdf Gee is that a long Website link.
I for one do intend to have a go at Making the 'Bonelle'. If anyone knows what Electric Motor it needs Please let Me know. I did find one site which seem to be saying 1/10 H.P. , but it sounds far to small. Well enjoy Everyone I hope the Links wo
I have just tried the Links Myself for some reason they are not working when You click on them on 'Woodworkforums' . They are actually working though so I will just type them in so you can write them down. They are www.metoolsonline.com and now the long one http://homepage.ntlworld.com/j.b.d.w...20drawings.pdf If You change 'drawings' to 'pictures' in the Link you will go to a Website with Pictures of the 'Bonell'. I may have fixed the Weblink problem anyway I had been spelling 'Bonelle' with two 'n's. The PDF is less than 1 MB. If anyone has any Trouble I can Email it to them.
ALL THE BEST Stewart steran50Last edited by steran50; 27th Feb 2009 at 08:01 PM. Reason: Weblinks not working.
27th Feb 2009, 07:49 PM #2Pink 10EE owner
- 6,218
Try this link http://homepage.ntlworld.com/j.b.d.w...onelle_tcg.htm
The link in the above post does not work as the forum software does not like it and removes some of the address
27th Feb 2009, 08:14 PM #3Diamond Member
- Sep 2006
- 53
- 1,010
Bonelle Tool and Cutter Grinder.
HI .RC, Thankyou very much for that. Now everyone can check out the Plans. I even tried writing the links in and not actually putting them in as a Weblink, but they still did'nt work. You are right though it does take some of the Address out. Perhaps someone knows another way of putting them in ?. I had not actually come across Your Weblink before. I will have a better look after Dinner. Have You actually Built the 'Bonell' Yourself ?.
Thanks again Stewart steran50
27th Feb 2009, 09:21 PM #4Pink 10EE owner
- 6,218
I have not built a Bonell TC grinder...In fact my grinders are limited to bench and angle..There was a discussion on Bonelle's on the HSM forum recently...I will see if I can find a link..Here we are http://bbs.homeshopmachinist.net/showthread.php?t=33153
And some more discussion here http://bbs.homeshopmachinist.net/sea...earchid=257401
28th Feb 2009, 10:14 AM #5Member
- Feb 2009
- Kyabram, Victoria, Australia
- 46
- 96
A bit of a noob question here, but what does one do with this device ??
Matt.
28th Feb 2009, 10:39 AM #6Diamond Member
- Sep 2006
- 53
- 1,010
What does one do with it
HI Matty5700, With the right attatchments (Attatchments might be standard - I don't know Yet) One can do a lot with this Machine. You can use the Machine to Sharpen Reamers, Dovetail Cutters, Lathe Tools, Slitting saws, End Mills, Slot Drills etc.
All the Best Stewart steran50
28th Feb 2009, 02:01 PM #7Senior Member
- Canberra
- 184
Hi Steran
Presumably you would use the same sized motor as on the quorn. You can buy motors and almost anything else you'd want for building a quorn here
http://www.hobbymechanics.com.au/quornpricelist.htm
What do you see as the advantage of the Bonell over the quorn? I wasn't aware of the Bonell, thanks for sharing.
28th Feb 2009, 02:24 PM #8Golden Member
- home
- 621
Apparently the advantage of the Bonelle is that it's all made from bar stock. The quorn is made from various castings.
Geoff
The view from home
2nd Mar 2009, 04:54 PM #9Senior Member
- Canberra
- 184
I see. Thanks Geoff
SOLD-quorn tool & cutter grinder casting kit-SOLD
By kats1719 in forum METALWORK GENERALReplies: 6Last Post: 10th Oct 2008, 05:23 PM -
Belt Grinder /Sanding Machine Plans
By barkersegg in forum METALWORK GENERALReplies: 3Last Post: 19th Mar 2008, 08:28 AM
