Results 1 to 4 of 4
Thread: Which wheel is which?
3rd Oct 2008, 10:45 PM #1Member
- Mar 2008
- Brisbane
- 54
Hi,
Me again. Can anyone tell me the best wheel for a 125mm bench grinder for shaping HSS tools bits for my lathe? It's only a cheap grinder and as such, the wheels that came with it aren't much chop.
Pat
4th Oct 2008, 02:55 AM #2
Dubbya ,
Aluminium oxide wheel (grey) ,is best , get a coarse grit for rough grinding the shape and a fine for finishing .Not sure what grits I have they just came with the grinder when I bought it.
A slip stone is good for honing after using the fine wheel.
For carbide tipped tools you need a silicone carbide wheel , which is the green one.
I've got to get a fine and coarse SC wheels as I have a big heap of carbide tools to dress up.
Now that I've thunk on it ........
I should just get another grinder set up instead of changing wheels all the time.Then I need one with wire brushes and another for the polishing mops.
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
4th Oct 2008, 06:17 AM #3Home Hobbist
- Oatley NSW
- 69
- 257
Here are some sites that have good information on Grinding Wheels;
http://www.ind.nortonabrasives.com/D...00000000003789
http://www.ind.nortonabrasives.com/home.asp
I also attach an article on grinding lathe tools, it maybe helpfull.
Regards,
Keith.
4th Oct 2008, 08:09 AM #4Member
- Mar 2008
- Brisbane
- 54
Ahhh, you guys never fail to deliver. Thanks very much
