Results 1 to 6 of 6
Thread: Band saw tension
8th Jul 2008, 07:28 PM #1New Member
- Feb 2008
- Qld
- 79
- 3
Band saw tension
HI All , this is my first post and would like some info, I have a metal band saw for which I have just purchased new bands as I have gone through a few they cut crooked after a while. They seem to have the teeth flattened on the inside of the band could this be because I have the tenison too tight or have I got another problem.
Thank you Rod
8th Jul 2008, 08:00 PM #2
Rod, a picture and a brand/model would help.
If the teeth are flattened on the inside it sounds like the rubber on the wheels may be worn.
Also, you said it is a "metal' band saw, you did mean it is made of metal, not used to cut metal didn't you?
8th Jul 2008, 08:08 PM #3New Member
- Feb 2008
- Qld
- 79
- 3
Hi, no it is a horzontal band saw to cut steel ,the pullys are steel the band is about 1640 mm 12mm deep 24 TPI sorry no pics
Rod
8th Jul 2008, 08:21 PM #4
Ok Rod, this may be better off in the metal working forum, but my guess is tension may be the culprit. That said though, I know very little about metal saws.
8th Jul 2008, 08:31 PM #5New Member
- Feb 2008
- Qld
- 79
- 3
Thanks for that I am trying to post on a another forum but having a few problems there.
Rod
8th Jul 2008, 10:29 PM #6Golden Member
- Nov 2005
- adelaide
- 597
welcome rod not sure if this saw is a new one but recently i got a used one and had to replace the guide bearings its not expensive maybe $30 for the 6, it made a world of difference see here for a link on how i set it up although its a different brand and model its very similar http://www.horizontalutilitybandsaw....hxa_Manual.pdf. mine is the common variety tiawanese rf 115 . the old guide bearings had the outside casing worn so they were slightly rounded they should be flat. the tension now doesnt have to be over the top just firm hand tightening of the screw.keep the sliding guides as close to the work as possible hope this helps
