Results 1 to 2 of 2
    Jul 1999
    St Ives, Sydney,NSW,Australia
    22
    Default Making a sheet metal tray
    I need to have a sheet metal tray made to go under a CNC mill to collect coolant run off. The tray would be approximately 1400 x 900 with a 30mm lip and a few bends. Anyone reccomendations on who I could approach to have this made in Sydney would be appreciated.
    Would gal steel be the most appropriate material?
    What thickness should it be?
    warren
    Jan 2004
    Mackay North Qld
    6,446
    Warren,
    Any general sheet metal shop will be more than capable.
    .6mm Gal or Zinc annealed will do the job
    With tabbed corners for spot welding or riveting its probably a 3/4 hr job and worth in the $50 to $70 range .
    If you wanted the corners welded count on a bit more as tig welding bumps up the cost.
  1. Sheet metal projects
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 19th Aug 2007, 11:31 PM
  2. Sheet Metal Folder?
    By Dylan SJ in forum METALWORK GENERAL
    Last Post: 25th Mar 2007, 10:42 PM
  3. Sheet Metal Roller
    By stevew in forum METALWORK GENERAL
    Last Post: 21st Nov 2006, 10:50 PM
  4. Inverter for sheet metal?
    By marz1 in forum WELDING
    Last Post: 29th Aug 2006, 08:33 PM
