Results 1 to 8 of 8
Thread: 9" Hercus tailstock disassembly
18th Nov 2007, 03:51 PM #1Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Dear members,
Would a kind Hercus owner please tell me how to disassemble the tailstock.
In particular, how is the lever fitted to the eccentric shaft. Is it a press fit, or is it screwed in. I've looked at a few diagrams I have, but can't make out the detail due to the poor quality pdf copy I have.
Assuming the two can be separated, will the eccentric shaft just slide out of the body?
I wish to strip the tailstock down, as part of an overall sympathetic restoration job.
Attached are two pictures to help clarify matters.
Regards,
Ken
18th Nov 2007, 04:34 PM #2
There is a pin that retains the eccentric shaft in the body. I think it is to do with the hole in the main body neear the handle, but can't recall.
With the lever to the shaft, that is a press fit out of memory. Although, When I overhauled on of the Hercus lathes at school we didn't even try seperate the two, mainly because there was no need.Have a nice day - Cheers
18th Nov 2007, 05:11 PM #3Most Valued Member
- 4,890
Never had to dismantle the tailstock,looking at it after removing your tailstock spindle crack the nut at the rear of tailstock and remove the complete assembly.
In regards to the locking lever its some type of pin that retains the shaft,the pin only locates the shaft(stops it coming out,the shaft floats).
It may be a selock pin or some other type,never taken the shaft apart.
You could try a small pin punch,give it a tap and see if it moves ,if it does, should fall into an open cavity.Remove shaft and reuse pin on assembley.
If it is a selock pin you will have to use a pin punch that suits the OD of the pin.
If you dont you may burr the end of the pin and make it very awkward to get your pin punch out.
Other choice is to drill the pin out and replace with a new one.
Never having taken it apart this is only my educated opinion.
18th Nov 2007, 07:12 PM #4Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I pulled a tailstock from a Herus 260 apart a few weeks ago and it took awhile to work out how the locking lever came out.
There was a grub screw that screwed in from underneath, I think, that located in a groove machined in the shaft of the lever.
I think the tailstocks are the same as the older models.
18th Nov 2007, 07:59 PM #5Product designer retired
- Nov 2006
- 79
- 2,074
Some clarification needed.
I can remove the eccentric shaft and lever, as one, from the tailstock body, it is retained by a screw, no problems. What I really want to know is, how to remove the lever from the eccentric shaft so I have two parts for easy polishing.
Some of the older Hercus lathes did not have an eccentric shaft and lever, they had a small spanner that locked the tailstock onto the bed.
Mine is the later type.
Ken
19th Nov 2007, 03:21 AM #6Most Valued Member
- 4,890
You would probably find that the end of the lever that goes into the shaft is probably knurled like the other end,probably just a slight interferance fit.
If you have access to a small press try and push it out,if not place in vice with soft jaws and give it a tap with punch and hammer.
(Just for my benifit what size screw,type of head was retaining the cam shaft thankyou)
19th Nov 2007, 12:10 PM #7Product designer retired
- Nov 2006
- 79
- 2,074
Hi Pipeclay,
Rather than attempt to describe the screw, as requested, I have attached a pdf drawing dimensioned in imperial units.
The tailstock eccentric shaft retaining screw is located in the underside of the body, and is accessible by separating the tailstock body from the tailstock base. Just release the set-over screws on each side of the tailstock, and the base will come off.
Ken
19th Nov 2007, 01:47 PM #8Most Valued Member
- 4,890
thankyou
Large Hercus lathes
By Greg Q in forum METALWORK GENERALReplies: 11Last Post: 6th Apr 2009, 09:59 PM -
Moving a hercus 9" lathe...one man job?
By Greg Q in forum METALWORK GENERALReplies: 17Last Post: 9th Apr 2008, 03:57 PM -
Adapting quick change tool post holder to suit Hercus 9" lathe
By neksmerj in forum METALWORK GENERALReplies: 10Last Post: 10th Jun 2007, 10:37 AM -
Hercus lathe motor details
By neksmerj in forum METALWORK GENERALReplies: 5Last Post: 25th May 2007, 04:53 PM
