Results 1 to 8 of 8
Thread: Aluminum Solder
26th Jul 2007, 08:17 AM #1Member
- Jul 2007
- Ipswich
Aluminum Solder
Hi, I am trying to find the person who was selling an Alloy solder for Aluminum. he had a stand at the Brisbane wood show, and I bought some.
It is great stuff, but now I need some more, and cant find he contact details.
any one know where I can find this guy to buy some more.
Sandy
26th Jul 2007, 08:38 AM #2
Do a search here, his details are here somewhere
DJ
ADMIN
26th Jul 2007, 08:46 AM #3
Was selling on Ebay.
Google "Duralloy"Hooroo.
Regards, Trevor
Grafton
26th Jul 2007, 06:48 PM #4
Contact details & info in this thread
Cheers................Sean
The beatings will continue until morale improves.
27th Jul 2007, 11:22 AM #5Senior Member
- Aug 2005
- Queensland
- 117
Was able to get it from Dick Smiths years ago as many wires were no longer copper but only copper coloured - I'm presuming it is for wires and not for soldering plate [not tried it but light plate should be possible but I would question the strength of it - you need to talk to a counter jumper who is in the know.
Regards,
Bob
27th Jul 2007, 11:47 AM #6
Nurgle, I had some stuff years ago called Techni2000, which was brilliant.
Using only a gas flame you could fill holes in Coke cans. All the boaties swore by it. I purchased it from a show so it may be the same stuff.
Try googling Techni2000.
Edit: Just read Scooters link. Oh well, better late than never.
27th Jul 2007, 01:38 PM #7New Member
- Oct 2004
- Wollongong
- 2
Here is another one out there called Durafix.
2nd Aug 2007, 12:46 PM #8New Member
- Jan 2007
- melbs
- 7
i successfully welded a rocker cover with some aluminium mig wire coiled up and mapp gas . i was worried about using those rods due to low melting points with a rocker cover. i assume a rocker cover wouldnt get past 300 degrees, but better to be safe than have a hole melted through your engine.
it was tough to get it up to temperature and to make sure the parent metal was welding to the child metal. best way to tell is to scratch the parent to see if it goes silver. also large portions of it can go sloppy and bend - like burnthrough with mig/arc welding but on a wider scale due to the temperature spreading fast.
id advise if your welding a large piece of aluminium to put it in the oven first to heat it all up due to how fast heat spreads in aluminium.
but those rods look pretty good. i would use them in a second with a crankcase or anything like that.
Silver Solder Pt 2 How to
By Grahame Collins in forum METALWORK GENERALReplies: 0Last Post: 11th Jan 2007, 10:51 AM
