Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Nov 2006
    Heidelberg, Victoria
    79
    2,074
    Default Centre punch mark magnifer
    Dear members,
    My eyesight is failing rapidly, so I need help.
    I have seen a jigger that was made in plastic, so I will try to describe it. It was circular about 50mm in dia and stood about 30mm high. In the top were two holes about 10mm in dia. One hole on one side, the other hole opposite. In one hole was a centre punch, in the other was a clear perspex rod with a domed top and cross hairs underneath.
    Looking down through the perspex, one could see two cross hairs, highly magnified, enabling it to be positioned exactly over two scribed lines.
    In position, the magnifer was removed, and replaced with the centre punch. A light wack, and a centre punch mark appeared, right on the spot.
    What's it called, and where do I buy one?
    Regards,
    Ken
    Jul 2007
    SUNSHINE COAST QLD
    22
    Some call it a scribe point,, and it could be what you talking about is a punch centre,, not too sure,,
    www.artemiswroughtiron.com.au
    classic creations/blacksmithing
    "possibilities are endless"
    Mar 2007
    Adelaide
    67
    32
    Ken,is this what you are looking for?
    Mike
    "Working to a rigidly defined method of doubt and uncertainty"
    Sep 2006
    Australind , WA
    58
    1,277
    What a neat little tool. I might have to get me one of them.
    Jun 2004
    Grafton, N.S.W.
    63
    185
    Are they available on OZ or do you have to buy from the US?
    Hooroo.
    Regards, Trevor
    Grafton
    Apr 2005
    Japan。
    49
    212
    Buy?
    It's not like this is beyond someone capable of a modicum of care. A piece of clear plastic, made round in a set size, a piece of drill rod the same OD and a base made of whatever you have.
    Takes a little experimenting to get the lens correct, but during machining a little polish applied to the end, while wet, will show you what the lens is doing. Once it's correct, polish it out and it will work fine. I am sure there are directions on the net somewhere.
    If you must 'buy', these are not a rare and strange thing and you should be able to find one somewhere for a reasonable price.
    Nov 2006
    79
    2,074
    Giday Schtoo,
    Sounds like you have made one of these optical centre punches. If you have, can you knock up a quick drawing, I reckon this would be a great little project for us novices. Units I've seen on the web are priced around the $50 to $60 mark.
    $50 is worth saving while having a bit of fun. There is no greater satisfaction than making one's own tools.
    Hope you can knock up a sketch,
    Regards,
    Ken
    May 2007
    Ballarat,victoria
    75
    Heres a few websites where they make there own .
    http://www.nucleus.com/~harlan/punch.html
    http://www.gadgetbuilder.com/OpticalPunch.html
    Hope this helps .
    Cheers Plushy
    May 2007
    Ballarat,victoria
    75
    Or buy one here .
    http://www.timbecon.com.au/products/...ols-321_1.aspx
    Google is your Friend
    Plushy
    Nov 2006
    79
    2,074
    Dear Plushy,
    Two holes are better than one, for storage reasons.
    Well, it seems no one has a drawing, will have to design my own.
    Can someone please tell me what radius needs to cut into the top of the perspex rod. Let's say its 12mm dia at the top, then reduced down to 10mm for the shaft. Is there any correspondence between the length of the rod, and the radius?
    The rest I can work out myself, and when drawn up, will be submitted to this forum for all to share.
    Regards,
    Ken
    Apr 2005
    Japan。
    49
    212
    I have not made a whole one, just the optics for one. I used an existing punch-stand like device and made an optic doohickey to fit that. It works ok, but not worth the effort of replicating from scratch.
    The optic rod is nothing really special, A large radius on the eyeball end IIRC, Something like 4-8 inches radius is enough, with a cross carefully scribed with a razor blade in the flat end. I might have done something else with the centre though, I can't remember right now. A good polish (the finer the better, I have a small tub of clear plastic polish, something so fine it hardly works till you need it to.) and Bob's yer uncle. I'd follow what those other sites have posted, since I made my quick and ugly version after seeing them.
    If you can, I'd also try and make the body out of something that will allow some light to pass. I dunno if it will make things much better, but I can't help but think that a solid chunk of metal is going to make things rather dim at the mark.
    Nov 2006
    79
    2,074
    Dear Members,
    I have prepared a drawing, in pdf format, of my interpretation of an optical centre punch. This might help a novice, like me, to make one.
    I guessed at the radius on top of the acrylic rod. Until I get around to making one myself, I won't know if it's right or not.
    Regards,
    Ken
    scooter's Avatar
    scooter is offline
    Super Moderator
    Dodgy brother
    May 2004
    Outer Melb SE suburb, Vic
    54
    719
    Rough enough, Ken.
    The beatings will continue until morale improves.
    Jan 2004
    Mackay North Qld
    6,446
    Default Radius Cutter for Optical lens
    Ken,
    If you read the text in links the radius for the lens was 9/16".
    The radius was cut using a tool post mounted radius cutter also described therein. The text mentioned a material called Lucite.
    In the links on those pages are descriptions and plans for the radius cutter.It is on my list of tools to make.
  15. #15
    Nov 2006
    79
    2,074
    Hi Grahame,
    I missed the bit about the radius, but picked it up on a second reading.
    Must get by gogs fixed or ease back on the "medicine".
    Thanks old son,
    Ken
