Results 1 to 15 of 26
Thread: home Made Power Hacksaw
11th Mar 2007, 06:55 AM #1New Member
- Mar 2007
- UK
- 5
I would like to make a power hacksaw, has any one plans? or has anyone made their own
I would very much appreciate any information, or links to any sites where these plans can be obtained. Thanks in advance.
11th Mar 2007, 10:24 AM #2
power hacksaw
Welcome mountpas
You don't have to be crazy here,but it sometimes helps. Anyway as most of them are probably not sober yet! or at least out of bed, it then falls to me to welcome you!
Being primarily a woodworkers site most of the mob here wouldn't get good value from a power hacksaw. As a person with metals trades background the venerable power hacksaw would be the last cutting tool, I would choose as it is too slow.
You may have different reasons for your choice , perhaps it may be cutting while you are doing another task.
The links came off Google and is old but I am sure they could be updated with modern techniques and materials. Popular Mechanics must have made plans for one at some stage,before they got people to buy stuff instead of making it.
http://www.vintageprojects.com/power...ct-hacksaw.pdf
http://www.vintageprojects.com/machi...er-hackSaw.pdf
best of luck
11th Mar 2007, 11:14 AM #3Member: Blue and white apron brigade
- 7,183
Firstly let me add my "welcome aboard" as well.
Q: How thick are the pieces you plan to cut?
For stuff under ~12 mm thick I use this dedicated table saw with a metal cutting disc. The water cooling described in this post is not essential. I normaly use it with a 125 mm diam x 1 or 1.6 mm kerf disc without water cooling. It makes fine smooth cust with minimal burr in metal that will strip the teeth of almost ant saw blade and is becoming my most used tool in my workshop.
For thicker stuff I use the metal band saw at work. I also could cut the smaller stuff on the saw but it's more convenient to have something at home.
11th Mar 2007, 11:31 AM #4Ring Master
- May 2006
- Lake Macquarie NSW Australia
- 73
Special Metal Cutting Blade - Circular Saw
There should be a metal cutting blade available now that will cut steel cleanly with out leaving a burr and not heating up the metal as it cuts. I used such a blade and battery operated circular saw to cut thin sheet, steel house frame and 25mm reo rod. The teeth on the blade were designed to only take a fine sliver of metal and could not dig in to stall the saw. Makita had a saw with a fixed base plate so that you could not adjust the depth of cut (always at maximum projection) and a pocket in the side of the blade guard to catch the swarf. After use you could empty the swarf into your hand and rub with the other. The swarf would not cut as it did not have sharp edges. Brilliant machine and blade (5'' I think) - I held a piece of thick (1') reo rod in my left hand and cut a piece off with rhe saw - the rod was cool to touch.
Hope this helps.
Linden
11th Mar 2007, 02:28 PM #5
Take a look at Lindsay Books, in particular Vince Gingery's "Build a Power Hacksaw with Vise."
http://www.lindsaybks.com/dgjp/djgbk/hack/index.html
Reading Lindsay's catalog is almost as much fun as woodworking.
JoeOf course truth is stranger than fiction.
Fiction has to make sense. - Mark Twain
11th Mar 2007, 07:49 PM #6
Would imagine you could buy a second handy and put fresh blades on it much more readily and cheaper, too.
But if you're really keen as mustard on building one, this might be of some interest...
See Here'What the mind of man can conceive, the hand of a toolmaker can achieve.'
Owning a GPX250 and wanting a ZX10 is the single worst experience possible. -Aside from riding a BMW, I guess.
11th Mar 2007, 08:22 PM #7
Same vendor even has details on catching snakes and tanning their skins
11th Mar 2007, 08:31 PM #8
Must be from Texas...
12th Mar 2007, 03:56 AM #9New Member
- Mar 2007
- UK
- 5
Thanks to Grahame,Bodl,linden,joe,and all for your time, and welcoming messages.
13th Mar 2007, 02:46 PM #10
Got two!
Hi Mountpas,
If you're interested, I have plans for two of the buggers.
The first, and in my opinion, probably the better, is a machine which uses a converted washing machine gearbox. The second is the old school mentioned earlier.
Let me now if you want them will e-mail them to you.
I'm going to build the washing machine job when i get back to Aussie in about a week!
FrostyA man who thinks that it can't be done shouldn't interrupt a man who's doing it........
13th Mar 2007, 07:52 PM #11Apprentice
- Mar 2005
- Hillman Western Australia
- 80
- 38
The Latest design for D.I.Y. Power Hack Saws.
Hello Mountpas and Welcome to the Forum, I have taken the liberty of uploading
5 Photo`s of my P.H.S., Now as this unit is still on the "Most Secrets List" you will
be required to eat the Photo`s after viewing. We cannot allow these to fall into the
hands of them pesky Yanks they`d steal the pattons for sure.
Regards,
John.
17th Mar 2007, 07:43 AM #12New Member
- Mar 2007
- UK
- 5
Thanks Beerbotboffin I would like to accept your kind offer, thanks also to J.Richards for the photos,
20th Mar 2007, 07:30 AM #13
e-mail
Hi Mountpas,
Mate, just send me your e-mail and i will send you the plans, no worries.
BeerbotboffinA man who thinks that it can't be done shouldn't interrupt a man who's doing it........
22nd Apr 2009, 11:19 AM #14New Member
- Coffs Harbour
- 5
Hi, just looking for some plans for a phs too. Would you still have a set you could email me?
29th Apr 2009, 07:25 PM #15Learner
- Sep 2006
- Brisbane
- 6
I have an old power hacksaw that I'd be happy to see go to a good home. No motor, but everything else seems ok. Located in Brisbane. Very heavy, pick-up only. Price ... whatever is reasonable? Cheers, peter 0438722643
Home made power feed for HM-45
By Sterob in forum METALWORK GENERALReplies: 30Last Post: 21st Jul 2007, 05:25 PM
