Results 1 to 6 of 6
    Apr 2006
    Newcastle
    10
    Default Sheet Metal Roller
    Looking for a small sheet metal roller for handyman use,any suggestions.any used ones out there??
    Does anyone have any plans for a home built model .
    Thank You
    Oct 2006
    Tallahassee FL USA
    82
    372
    Chap named Dave Gingery wrote a small book for DIY slip roll. Available at Lindsay Books (elsewhere too probably). Lots of other neat stuff at Lindsay. Also fun to read his catalog. He's just as crazy as we are.
    Google "lindsay books" for link.
    Joe
    Of course truth is stranger than fiction.
    Fiction has to make sense. - Mark Twain
    May 2004
    Epping.Vic
    58
    195
    I am not sure what width roller you were looking at making but here are a couple of links that may help.
    http://www.metalwebnews.com/howto/rolls/rolls.html
    http://users.bigpond.net.au/ggoodacr...iy/roller.html
    http://www.integerspin.co.uk/beadroller.htm
    Al .
    You don't know, what you don't know, until you know it.
    Andy Mac Guest
    Hi Steve,
    I've made a couple of small ones, probably too small to be of any use to you, but they do work. The first one would be suitable for model making and jewellery, although I made it to roll small rings of aluminium sheet for some artworks. It has 2 rubber rollers, one driven by a simple crank, and an adjustable aluminium roller, all about 200mm in length. The adjustable one is carried in a pair of filed brass blocks, which slide in slots cut through the end frames, and is moved by two captured bolts with small cranks on top. The end frames are bolted (machine screws) to stretchers of aluminium extrusion.
    The photos here show a couple of items I quickly rolled as samples, all put back in place for the shot!
    Andy Mac Guest
    Another shot, from the front. The wider piece of metal is steel, 0.5mm thick, the aluminium strip is about 1mm and the steel wire is 2mm in diameter.
    Nearly all the parts were scavenged from an old photocopier, which provide a wonderous assortment of shafts, framework, gears, rollers and mating bushings.
    Andy Mac Guest
    And here is another roller, this one specifically designed to roll aluminium tubing...recycled from TV antennas, so the diameter was fixed. Again, made for production of artwork.
    I turned hardwood rollers (spotted gum) and profiled the groove using a specially built turning tool to get the diameter right. The two outrigger rollers adjust to advance the curve radius. They are held in place against the backing board in T-slots routed into the surface.
    This machine works OK, as can be seen by the rolled tubing, but the crank is a bit of bugger. It should have been fitted to the other side, out of the way of the rolled tube as feeds off the roller.
    So I think it is possible to construct your own roller, but I haven't been ambitious in scale. It may not turn out very versatile, but go and have a good look over commercial ones and go home to adapt the ideas. BTW, I did the rudimentary turning on the first one using a drill press for a lathe
  1. New Metal Spinning DVD
    By metal spinning in forum METALWORK GENERAL
    Last Post: 5th Dec 2008, 11:25 PM
  2. Sheet Metal Folder?
    By Dylan SJ in forum METALWORK GENERAL
    Last Post: 25th Mar 2007, 10:42 PM
  3. Inverter for sheet metal?
    By marz1 in forum WELDING
    Last Post: 29th Aug 2006, 08:33 PM
