Results 1 to 5 of 5
Thread: Lever Dial Indicator
4th Nov 2006, 12:46 AM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I am after a Metric lever type dial indicator that has the lever perpendicular to the body of the indicator. I want to be able to have the face of the indicator facing upwards while finding the centre of a hole on my milling machine. I have seen a pic of one but can't seem to find one to buy. Does anyone know where I can get one from?
I have got a pdf file for the Measumax range and one in that(34-128)
seems to be capable of it but the business I ordered it from says no. I have searched for a Mitutoyo model, but can't find one either. Any help appreciated.
Sterob
4th Nov 2006, 08:36 AM #2
4th Nov 2006, 10:48 PM #3Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks for the link. I had a look at their site, but couldn't see any like that. Sent them an email and will see what they say.
5th Nov 2006, 11:11 AM #4Novice
- Nov 2005
- Seaton, South Australia
- 13
Hi Sterob,
My TESATAST Dial Indicator can perform that task. It has 25mm Dial and reads 0.01mm increments. TESA is the brand name, I think they are a Swiss company.
The deflection lever can be moved through an arc of approx 250 degrees so a 90 degree bend reletive to the clock face is no problem. The levers come in different lengths and can be interchanged according to the depth you may be measuring.
I do know that it was expensive to buy (25 years ago) and I have had it serviced once (cost $70) but it has been worth the cost.
"Google" TESA and see what comes up?
Regards,
Gary.
6th Nov 2006, 02:08 PM #5Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks Gary.....Will check them out.
Apparently Brown & Sharpe make one as well.
