Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Aug 2006
    1,105
    I found some 2mm aluminiun angle that should work and some m3 countersunk torx headed screws. I was planning on using 2 screws maybe 10mm in from the ends, could possibly add a third in the middle if required.
    Will probably use 5mm aluminium to mount the reader to.
    Sent from my SM-N986B using Tapatalk
  2. #17
    Aug 2006
    1,105
    Hi Dave,
    This is what I ended up with. I still need to make up a stop in the carriage to protect it from the tail stock, will probably use an m5 or m6 cap screw.
    Drill out 4 x 4mm holes to access the gib screws
    Also a cover to protect it a bit better.
    It's working without any adjustment to the sensor so that is good news.
    I had to make a converter plug for the wiring as that was all wrong.
    Next will be to install a glass scale in the Z axis
    Here are a few photos of progress so far
  3. #18
    Dec 2013
    56
    1,414
    Nice, what I did for the tailstock stop was to add a way wipers to the tailstock, then I used one extended way wiper bolt as the stop, 2 birds with one stone, so to speak.
    I used a socket head bolt, then a nut.to fastern the way wiper back on that side.
    A simple plastic cap I had laying around finished it off.
    It has been working fine for 15+ years and saving any crap under the tailstock.
    Sent from my SM-A235F using Tapatalk
    Using Tapatalk
  4. #19
    Dec 2013
    56
    1,414
    The way wipers were simple made out of standard thin sheet metal bent in the vice with a hammer,.and a.bit of felt
    Using Tapatalk
  5. #20
    Aug 2006
    1,105
    Where did you source the felt from, I'll add wipers down the track to the tail stock but for now I just added a stop to the crossslide using a m4 bolt, I probably should add wipers to the cross slide as well.
    I made up the cover over the weekend, it just clips into place as it is a tight fit, I don't think I will screw it in at this stage. That's the x axis done, now need to work on the z axis.
  6. #21
    Dec 2020
    Geraldton Western Australia
    132
    Try Spotlight for the felt, that's where I got mine from.
  7. #22
    Dec 2013
    56
    1,414
    I got some from a friend, but I have been looking to buy more from these guys.
    There are plenty of thicknesses available.
    https://www.ebay.com.au/itm/30372304...mis&media=COPY
    Using Tapatalk
  8. #23
    Dec 2013
    56
    1,414
    Nice install, I'm not sure I'd worry about a cover, but it would help to keep the tiny swarf of the tape.
    Using Tapatalk
  9. #24
    Aug 2006
    1,105
    I figure extra protection shouldn't hurt. It only takes up about 1mm of usable travel space.
    I'll grab some of that felt too, I should start looking into lead screw covers as well and possibly something for the ways to try and keep it a bit cleaner.
  10. #25
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,528
    Quote Originally Posted by Com_VC View Post
    You really want good quality wool felt that is reasonably thick. Try places that repair pianos.
  11. #26
    Dec 2013
    56
    1,414
    That stuff is advertised as A grade, they also have B grade and thicknesses up to 6.4mm from memory.
    Using Tapatalk
  12. #27
    Dec 2013
    56
    1,414
    Im not sure what lathe you have, but his is my way, gap and leadscrew covers that have been on for around 18 plus years now.
    The only time they ever get in the way is when using the faceplate, then the carriage one is easily removed as it's only attached with the 2x was wiper screws, the leadscrew one has 2x screws also into 2x factory holes where the rack would have gone for a left hand carriage handwheel.
    The gap one just sits in there, and because of the way the ways are machined, there is a recess, so it's lower than the ways allowing the carriage to pass over.
    They do not interfere with maximum diameter turning either.
    They keep 100% off the ways for general jobs unless working between centres, and the leadscrew one 98%
    Using Tapatalk
  1. Magnetic Linear Scale
    By Salv in forum METALWORK GENERAL
    Last Post: 14th Feb 2023, 10:54 PM
  2. Chipmaster DRO installation
    By swarfless in forum SHOW & TELL
    Last Post: 11th Dec 2022, 04:29 PM
  3. 1 Tonne crane hook scale/ hanging scale needed
    By caskwarrior in forum WANTED TO BUY
    Last Post: 27th Apr 2017, 02:29 PM
  4. Hercus 260 DRO installation
    By Pete F in forum THE HERCUS AREA
    Last Post: 25th Nov 2015, 08:39 PM
  5. Top Hat Installation Info
    By bagman in forum METALWORK GENERAL
    Last Post: 27th May 2014, 10:29 AM
