Results 1 to 10 of 10
Thread: Cutting a spline with the lathe
17th Mar 2023, 06:49 PM #1Most Valued Member
- 5,945
Saw this on you tube and thought it an interesting way to cut a spline on a shaft with the lathe. They called it a gear, but to me it's more of a spline.
Please do not complain to me that it's abuse of the lathe, I submitted it as what could be done in a pinch.
https://www.youtube.com/watch?v=U7TtqyDFzlI
Cutting an internal spline, similar concept
https://www.youtube.com/watch?v=BczEh2hFFrY
17th Mar 2023, 07:23 PM #2
Those Indonesian machinists can get fairly creative with their "mesin bubut" and "mesin kumai"
Interesting dividing technique. Probably how it was done a few centuries ago.
Safety issues aside there have to make do with what they have. Most job shops don't even have a fire extinguisher and usually no one is wearing any shoes
17th Mar 2023, 08:36 PM #3Most Valued Member
- 5,945
Hi Kafie, I'm glad that you could understand that writing, as I forgot that you lived there for a while.
It's amazing as to what they can do with so little equipment.
17th Mar 2023, 10:41 PM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
The lathe or "prince of machine tools" has many of the elements of other machinery.
Here they have adapted one for use as a shaper, and then as a milling machine.
Holding the job in place seems to be achieved just by severely tightening the tailstock ram.
That doesn't appear to be positive, but has evidently been successful here.
I've seen that type of spline referred to as serrations. Not much good as a gear I think.
18th Mar 2023, 11:26 AM #5Golden Member
- Dec 2007
- 574
I've cut internal splines on the lathe a few times in the past, racked the saddle back and fwd by hand - it does work but gets tiresome very quickly. I cut the tapered internal spline on a steering wheel boss for one of the kid's car projects, to index I used wrapped a length of brown paper around the chuck back plate, removed it and then divided it up with pen marks according to the number of splines, taped back onto the back plate with a simple wire pointer next to the chuck was good enough, it was fortunately only about 18mm long and aluminium so soft enough to cut each spline in one go - I had to use the top slide to advance the cutter rather than the saddle as the spline was tapered.
20th Mar 2023, 08:57 PM #6Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,185
The second video (internal spline) shows some things I found interesting;
1) When he parts off the tube, there was a very good wiggling action –
ensuring clearance for the tool in the slot it was cutting.
2) Somehow, this lathe allows disconnection of the spindle from the feed/lead screw.
I have never used one that allows that, but some lathes have many clutches.
However, it seems he just selects E on the gearbox,
and then the thread cutting screw turns independently to the spindle????
3) When the cutter is nearing the end (closest to the chuck),
it seems it kicks in toward the centre.
Couldn't tell if this was quick turn out of the cross slide,
or something to do with the motor reversal rocking the saddle.Nigel, from a cave FULL of unfinished projects and lost tools.
20th Mar 2023, 09:46 PM #7
I will have to watch the video again but IIRC:
I thought the operator used a live center in the spindle and a dead center in the tailstock which under friction/pressure from the tailstock should keep the part static (independent of spindle rotation) and allow using the carriage under power feed to cut the spline.
20th Mar 2023, 10:34 PM #8Mechanical Butcher
- Oct 2004
- 1,894
I agree.
It's probably just as well to cut from the left to right, to add to the "braking" effect.
21st Mar 2023, 12:33 PM #9Diamond Member
- Aug 2019
- 56
- 1,185
21st Mar 2023, 01:37 PM #10
Sorry, What second video? I just saw the second video.
Interesting, and I have not seen this feature before built in a lathe before.
On the kind of lathes we have at home, we could still do this with a live center in the spindle. And for extra work holding replace the dead center in the tail stock with a tailstock chuck.
Harrison M250 Change Gear Test Spline
By electrosteam in forum METALWORK PROJECTSReplies: 12Last Post: 16th Mar 2017, 11:45 AM -
Thread cutting on the lathe ??
By welder in forum METALWORK GENERALReplies: 126Last Post: 27th Oct 2012, 02:37 PM -
Cutting keyways in the lathe
By shedhappens in forum METALWORK GENERALReplies: 16Last Post: 26th Aug 2012, 09:56 AM -
Spindle spline clamp for bad fitting splines
By Dave J in forum METALWORK GENERALReplies: 2Last Post: 10th Sep 2010, 10:07 AM -
Spline Spanner
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 18th Sep 2007, 08:01 PM
