Results 1 to 10 of 10
    Sep 2006
    Australind , WA
    58
    1,281
    Default Ideas for Pole lowering setup for Shed Internet
    I am brainstorming ideas for a job I want to do soon.
    I have Ubiquiti Radios for a wireless connection to my shed for Internet.( Everyone need the 'Net in the shed, don't they?)
    The radios are Line Of Site, so I need to use a Hockey Stick mount on the house to get that. Shed side will mount on the gutter.
    For convenience for WHEN it fails, I want to incorporate some sort of 'hinge' in the base of the pole, so I can lower the radio to work on it.
    The 'Swivel pole' device looks perfect, except they look complicated and time consuming to fabricate.
    Radio is not heavy. Pole is approx 1300mm high?
    Anybody seen anything that might be suitable?
    Apr 2021
    Adelaide
    212
    Can't you take a bolt out of the hockey stick and lean it over?
    I used powerline network adaptors to get Internet in my workshop - it just requires a common phase.
    Jack
    6,482
    Hi Steven,
    For years I had a wooden 8' X 10' shed that I used as my radio shack and had a 144/146 collinear antenna screwed to the shed wall with a "Hockey Stick" very similar to the first picture. I had an 1/8" thick steel plate on the inside and two 1/4" whit bolts from the outside holding it. I used to remove one bolt and swing it down, using one bolt as a pivot. That worked well for a number of years. Until I got a 75 foot crank up tower and started using Yagi's.
    Sep 2006
    Australind , WA
    58
    1,281
    Quote Originally Posted by Jack Ryan View Post
    Jack
    No. No room to swing sideways as the location is in a recess in the side of the house ( Alcove?)
    Nov 2017
    Geelong, Australia
    57
    2,674
    How about just welding a short vertical tube to the side of the hockey stick after the bend, and slipping the actual antenna mounting pole up inside that tube.
    Would need some sort of rotational locating to keep the directional alignment, and obviously some sort of pin etc to keep it elevated.
    For maintenance pull the pin and the pole drops down. With a short one like that there’s no significant weight so just support it by hand as it comes down.
    Have you used the Ubiquity radios before? They’re rock solid IME, and unlikely you’ll be pulling it down again in less than a few years - so not like you need a quick lowering mechanism for frequent access.
    Oct 2004
    Southern Highlands NSW
    1,898
    Hinged poles are on some railway stations.
    Jan 2005
    Sydney Australia
    77
    15
    Just a thought, if this is to be mounted on a facia or similar, make a backplate for mounting and hinge it to the bottom of the hockey stick mounting plate then secure to the backplate/fascia.
    Mar 2014
    South of Adelaide
    1,229
    Those Ubiquity units are super reliable, we have one at work that has been going 5 years without issue. our customers also use them up in the cooper basin as they are very reliable.
    Sep 2006
    Australind , WA
    58
    1,281
    Thanks Guys.
    @Jack Ryan I do have some Powerline Adapters as well. fOr some reason I discounted them due to the tortureous path for the signals.....through three SWBD's to shed. I just had that in my head....I might bust them out...thanks.
    @nadroj Yeah, I've seen some power poles that are hinged. Not easy to replicate.
    @apple8 Yes, on a facia.So it hinges down on the hockey stick mounting plate? Thats an option.
    @snapatap Yes, I've used them before. You know what they say, never say never....lol I'm an Amputee so SWMO will give me stink eye if I climb a ladder.....
    thanks
    Mar 2011
    Southern Flinders Ranges
    1,555
    We have CCTV equipment on those swivel poles at work, I have nothing nice to say about them…
    Ive installed probably a hundred or so UB links in the last 10 yrs (about half of them in the Cooper Basin and along the Gas/Petrochem pipes that heads south out of Moomba as it happens) and they are bomb. Have a look at Melbourne Satellites site, they have a heap of different mounts.
  1. 50NB galvanised steel pole joints
    By Jimmayo in forum METALWORK GENERAL
    Last Post: 6th Dec 2021, 07:15 AM
  2. WTB: 1Hp - 0.75kW - 2-pole 3-phase motor
    Last Post: 21st Mar 2021, 08:39 PM
  3. Help me make a rotating rod / pole thing...
    By somersetpaul in forum METALWORK PROJECTS
    Last Post: 1st May 2019, 02:44 PM
  4. Lowering a bridgeport from a stand
    By j3dprints in forum METALWORK GENERAL
    Last Post: 14th Dec 2018, 02:43 PM
  5. Solar panels on metal shed - ideas
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 29th Jul 2014, 08:59 PM
