Results 1 to 2 of 2
29th Sep 2022, 07:01 PM #1New Member
- Sep 2022
- 4
Bent Cross Slide Screw - Sheraton/South Bend 9a
Hi there,
Putting back together a Sheraton 9A that I bought as a 'kitset'
She looks to be on pretty good condition - but I'm certainly no expert.
Anyway, the Cross Slide Screw is bent (see attached short video). Its not much - I would say 2-3mm at the end.
Can I heat the shaft and straighten? Or what's the preferred approach to fixing this?
Produce.mp4
Graeme
29th Sep 2022, 07:14 PM #2Most Valued Member
Hi and WELCOME to a TOP FORUM.
I'd say that you could straighten it cold, using a garage press, which would be best. If you don't have one, I'd use a vise, as there is more control in the pressure applied to it.
Mount it in a couple of V blocks, or fab some angle to create a couple, that way as it's turned you'll see/measure the high spot and then press it down. If using a vise you'll need to sit it on a bench to measure/find the high spot.
Don't use a hammer, unless it's a brass or nylon faced one, otherwise you could damage the thread.
HTH
Sheraton cross slide and compound slide spindle threads
By ajbvicau in forum SHERATON AREAReplies: 5Last Post: 20th Jul 2021, 10:43 PM -
Metric cross slide screw.
By pipeclay in forum THE HERCUS AREAReplies: 14Last Post: 20th May 2011, 11:59 PM -
sheraton A cross slide nut
By danielhobby in forum THE HERCUS AREAReplies: 5Last Post: 21st Apr 2011, 07:50 PM -
South Bend/Hercus Cross slide nut
By YarrD in forum THE HERCUS AREAReplies: 2Last Post: 14th Dec 2010, 11:34 PM
