Results 1 to 15 of 15
Thread: Punch
23rd Sep 2022, 10:55 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Punch
23rd Sep 2022, 11:16 PM #2Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 314
You've got to drill a hole for the bolt so why not keep going & bring it to the size you want with a step drill?
For clearance work on 10% of material thickness.
24th Sep 2022, 10:58 AM #3Senior Member
- Nov 2012
- 423
24th Sep 2022, 12:39 PM #4Golden Member
- Dec 2007
- 574
I have 2 and would a like a third one at 20mm and was contemplating to diy one as well, let us know how it turns out - here are mine the clearance is in the order of .05 - .06 mm or around a thou' or 2 - bear in mind that mine have a thin coating of rust and that calipers are not really a precision instrument when it comes to inside measurement. The first time I used one of mine I was surprised at how effective they are, I didn't really expect it to punch through a 150mm C section purlin bit it did work.
24th Sep 2022, 03:53 PM #5Senior Member
- Nov 2012
- 423
24th Sep 2022, 05:30 PM #6Diamond Member
- Aug 2006
- 1,106
I didn't think they were that expensive to buy. $18
https://www.ebay.com.au/itm/31298905...mis&media=COPY
Sent from my SM-N975F using Tapatalk
24th Sep 2022, 06:19 PM #7Senior Member
- Nov 2012
- 423
You're kidding !
I searched and searched and the best I could find was just over 100 bucks from RS components or a kit of 6 from Amazon for 400.
I would have just bought one if I knew that.
Ah well, too late now.
and, I'm astounded. It worked and worked really well.
If anyone's wondering how I got the shape of the punch :
24th Sep 2022, 07:00 PM #8
Hi Phaser, Guys,
My hole punches all have only two scallops in the punch, 180 degrees apart, even the big 50 mm one. The only thing that changes is the HT bolt size.Best Regards:
24th Sep 2022, 07:20 PM #9Most Valued Member
Nice work
From memory they're called a Chassis Punch.
24th Sep 2022, 07:34 PM #10Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
What material did you make it from, is it hardened? The genuine Qmax and other brands of chassis punches are hardened.
24th Sep 2022, 08:13 PM #11Senior Member
- Nov 2012
- 423
25th Sep 2022, 01:36 AM #12
Talking about hardening, I remember many years ago a blacksmith showing me how to harden stone work chisels, he heated the end until it was red hot and then pressed it into a wooden block, it stank something rotten. He did this several times each time reheating it, then reheated it and plunged it in water before grinding the end.
I don't really remember how good or effective the hardening was, but I do remember the awful stink !Best Regards:
25th Sep 2022, 01:56 AM #13Most Valued Member
25th Sep 2022, 05:08 AM #14
Hi Kryn, Guys,
It is surprising how a comment triggers bits and pieces of memory, long lost in the past ! Oddly it was the mention of hardening that brought back the memory of the horrible smell of burning charring wood !
I wouldn't have been very old, maybe around 14 or 15 years. The forge was a few hundred yards down the street. I used to go in, talk to him and watch him hammering out pieces of red hot iron, making horse shoes, pokers and coal rakes. Both my Mum and Gran had fire guards that had been made by him. Mum used to dry washing on ours around the kitchen fire.Best Regards:
26th Sep 2022, 04:07 PM #15Senior Member
- Nov 2012
- 423
I'm going to buy a few of those ebay ones so it will make up a set, in case I need one in the future.
Thanks Com_VC
Punch
By phaser in forum METALWORK GENERALReplies: 1Last Post: 23rd Sep 2022, 11:21 PM -
2” wad punch etc.
By clear out in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 22nd Feb 2021, 05:40 PM -
Wad Punch Question
By SurfinNev in forum METALWORK GENERALReplies: 12Last Post: 1st Nov 2017, 09:45 PM -
Old Moorite Punch
By Picko in forum METALWORK GENERALReplies: 11Last Post: 20th Apr 2015, 05:35 PM -
Metal Tab punch?
By jared.c.rogers in forum METALWORK GENERALReplies: 6Last Post: 8th Sep 2011, 02:52 AM
