Results 1 to 15 of 35
Thread: Compressor Service Cost
20th Sep 2022, 10:49 PM #1Most Valued Member
The compressor at work hasn’t been serviced for over 10 years. It’s one of these: https://www.grays.com/lot/0002-30194...air-compressor
According to AS3788 this compressor should have an internal inspection every 4 years and an external inspection every 2 years (assuming my estimate of the tank capacity is correct).
I’ve received the following quotes from one company:
- $360 for an internal inspection of the tank.
- $470 to service the compressor (includes oil and air filter change).
- $315 to fit a new three phase pressure switch (condor MDR3).
Do these prices seem reasonable?Chris
20th Sep 2022, 10:52 PM #2China
- Dec 2005
- South Australia
- 1,658
Seems reasonable to me so long as you received a certification.
20th Sep 2022, 11:08 PM #3Most Valued Member
No idea, but out of interest, is the new pressure switch because the current one failed or is it a code thing?
21st Sep 2022, 08:20 AM #4Pink 10EE owner
- 6,218
21st Sep 2022, 08:58 AM #5Most Valued Member
It leaks after the compressor shuts off, which quickly drops the pressure about 20PSI and the compressor starts again. I believe there's a valve inside it that is prone to failure. Whether that valve is replaceable I don't know. I just asked them to replace the whole assembly.
21st Sep 2022, 09:06 AM #6Most Valued Member
That was my thought too. I'm OK with the cost of the pressure switch and tank inspection, but $470 to change the oil and filters seems OTT. I could do that myself for well under $100. They don't even tell you what they do during a service. I had to ask. We're a school, and I suspect there my have been bit of a markup for that. And everyone seems to be gouging now anyway.
I think I'll cancel the service and just get the switch and tank inspection done. The AS doesn't require servicing anyway. Just internal and external inspections.Chris
21st Sep 2022, 09:49 AM #7Member: Blue and white apron brigade
It's only 4HP (3kw) and I agree about the service cost as anyone can do this as it usually just involves changing the oil and filters and checking for leaks on the joints.
Inspection charge sounds about right for that size compressor, as its similar with the only quote I have heard of for inspection/testing and recertification.
In 2016 the mens shed I was a member of bought this 10 year old 7.5kW 1500 L/m compressor with a 200L? tank from a high school for $800. It was in perfect working order but the school needed to have it inspected and re-certified and the quotes they got for this was around the $800 mark. A few years earlier they had obtained a large Govt grant for upgrading their manual arts gear and instead of re-certifying the compressor, replaced the reciprocating compressor with a large screw type with refrigerated cooling. They had also setup a woodwork class room with reticulated air to every bench and a heap of air tools but this gear was no longer used as the teacher who had set this up had left and not enough students were choosing WW as an option in later years when this gear as being used. The students preferred doing things like CAD, 3D printing, laser engraving, and jewellery making which at least involved some metal working.
21st Sep 2022, 10:26 AM #8Most Valued Member
- 2,673
Out of interest - I checked with our facilities guy at work, and the last receiver internal inspection he had done (a 330L vertical) was $600.
21st Sep 2022, 04:34 PM #9Most Valued Member
22nd Sep 2022, 01:59 AM #10Senior Member
- Aug 2007
- 292
May I ask what goes into an internal inspection? I've never heard that wording used before. Is it the same as hydrostatic testing?
Pete
22nd Sep 2022, 08:31 AM #11
22nd Sep 2022, 09:28 AM #12Most Valued Member
From the Australian Standard:
"An internal inspection gathers information about the condition of internal surfaces and usually requires confined space vessel entry or visual inspection using equipment such as boroscopes or video scopes. However, internal inspection may also be executed by appropriate non-intrusive means (e.g. ultrasonic or radiographic testing), where a high degree of confidence can be demonstrated in the reliability of such techniques. Care is needed to ensure that sampling is truly representative of the condition of equipment. Where practical internal inspection may be carried out whilst the equipment is operating."Chris
22nd Sep 2022, 09:51 AM #13Most Valued Member
- 4,258
To follow the standards are for those who wish to ensure their insurances are going to pay out in the event of something going wrong.
In other words if its for home/domestic/handyman use, where monetary rewards are not being exchanged, I wouldn't bother.
22nd Sep 2022, 11:11 AM #14Most Valued Member
Yep, that's why I don't have my home workshop compressor inspected. However, this one is in a school.
There's also Worksafe to consider too. They'll have a field day if something goes wrong and all the required inspections haven't been done.Chris
22nd Sep 2022, 01:01 PM #15Senior Member
- Near Rockhampton
- 270
I assume it wasn't a fault with the non return valve then.
https://metalworkforums.com/f65/t207...mpressor-issue
How much will this cost to cut?
By gazza2009au in forum METALWORK GENERALReplies: 24Last Post: 10th Jun 2016, 12:19 PM -
About a low cost Tailstock Turret...
By cba_melbourne in forum METALWORK GENERALReplies: 7Last Post: 13th Jan 2015, 07:49 AM -
Cost of Propeller Boring
By electrosteam in forum METALWORK GENERALReplies: 19Last Post: 20th Dec 2013, 01:42 AM -
What's a Tap cost these days?
By barkersegg in forum METALWORK GENERALReplies: 32Last Post: 17th Oct 2012, 02:56 PM -
International post cost!?
By DoctorWu in forum METALWORK GENERALReplies: 7Last Post: 21st Jul 2011, 06:17 PM
