Results 1 to 10 of 10
31st Jul 2022, 01:07 AM #1Novice
- 19
HSS taps & dies - Sutton, LPR (Aprica), other?
Hey folks
I’m looking to upgrade from my cheap tap & die set, and looking for recommendations available in Australia. I’m looking for HSS in order to have a better time of cutting new threads on/in mild steel. Two offerings I’m comparing are the Suttons and Aprica - (the LPR toolmakers house brand?). I imagine the Suttons would be pretty decent, but does anyone have experience with the Apricas, or have another brand to suggest?
cheers
Will
31st Jul 2022, 02:21 AM #2Most Valued Member
- 5,942
Bordo/Goliath tools are what I use, I haven't had any problems, but have had a few broken by the klutz's at work!!! Don't know how they manage to break a 12mm tap???
31st Jul 2022, 10:31 AM #3Most Valued Member
- 2,651
I’ve got a couple of the Aprica ones in odd sizes. They work but I wouldn’t put them in the Sutton league from a looks/finish perspective. I don’t have the same size Sutton so can’t compare them in use.
My approach is to have a good size set of midrange quality, and then buy individuals of the ones I commonly use such as 6,8,10,12mm.
My big set is just a Total tools TTI brand one from about 3-25mm in coarse and fine pitches.
Ease of threading is as much about good lube and correct hole/shaft size as the tool in my experience. For my commonly used taps I keep the correct drill size stored with the tap.
31st Jul 2022, 10:45 AM #4Gear expert in training
- 34
- 1,075
We mainly use Guhring at work, very nice stuff
31st Jul 2022, 12:56 PM #5Most Valued Member
31st Jul 2022, 03:00 PM #6
if you are patriotic there is a Capital Tools of Hamilton Victoria.
They make taps and dies and similar tools.
I bought mine bits and pieces from the dealer who supplies the big machine shops in our area. Its around the same pricing as the rest of the OS good stuff.
I have never had any problems and their stuff has all been top quality.
Here is their email.
[email protected]
The usual disclaimer, no relatives or affiliations.
31st Jul 2022, 04:05 PM #7Most Valued Member
- 2,651
Thanks Grahame - almost local to me and I hadn't heard of them.
Link to their website here, and there's even a price list !! https://www.capitalcuttingtools.com.au
31st Jul 2022, 05:47 PM #8Most Valued Member
31st Jul 2022, 05:51 PM #9
If you are looking for a full set you might even consider
a Gearwrench set.
https://www.totaltools.com.au/80324-...d-die-set-3886
They are NOT HSS but I have a set and they do very well on steel and brass,though today I did cut a M6 x 1 thread on a 304 S/Steel rod.
They use hex die nuts, not split dies.
The taps are ok though when I break the smaller ones they are replaced with Capitol HSS equivalents.
I have a set of Gearwrench imperials as well.
No problems other than the ones I have caused over 5 years or so.
If you have the opportunity have a look at them in the flesh so you can see the quality of the tap and die wrench design.Well made and solid.
These wrenches far better than the alloy junk that comes with some of the allegedly better HSS sets.
31st Jul 2022, 08:40 PM #10Senior Member
- Dec 2020
- Geraldton Western Australia
- 132
I use Bordo for mild steel/ali and Golith or Sutton HSS for stainless and anything else hard.
WTB - UNC/UNF taps and dies
By OxxAndBert in forum WANTED TO BUYReplies: 6Last Post: 3rd Sep 2020, 10:28 PM -
Sutton taps
By woodfast in forum METALWORK GENERALReplies: 6Last Post: 16th Dec 2013, 12:37 AM -
WITHDRAWN: P&N and Sutton Hand Taps & Dies
By Ben + in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 3rd May 2013, 08:55 PM -
taps and dies
By doug3030 in forum METALWORK GENERALReplies: 23Last Post: 10th Mar 2012, 01:44 PM -
Taps & Dies
By footz in forum METALWORK GENERALReplies: 22Last Post: 6th Oct 2008, 07:11 PM
