Results 1 to 5 of 5
    Feb 2012
    Tamworth, NSW
    205
    Default Tightening up a thread using an o-ring?
    I’m after some quick advice about tightening up a M10 thread on an aluminium part. I have a very nice fit up and feel except there is nothing to really hold the tightness when doing up finger tight (this is a pen barrel) and it can come lose relatively easily. I think I could just add an o-ring to give some “grip” to the two surfaces of the parts. Is the approach here to just cut a groove where my thread relief is and seat a ring so it sits just proud of the surface? Any more to it than that?
    Ian
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Danger Mouse View Post
    That would work, but what's the wall thickness at the thread relief? I've made plenty of metal pens, and keeping adequate wall thickness is always an issue if you don't want the pen to be too thick.
    Feb 2012
    Tamworth, NSW
    205
    Thanks Jack
    The thread is M10 and the inside hole diameter for the refill is 6.3mm so probably have enough to sneak it in if I can get a nice fine o-ring.
    Nov 2007
    melbourne australia
    3,228
    ...so probably have enough to sneak it in if I can get a nice fine o-ring.
    Should be OK. Depends how generous you were with the thread relief cut. Would be worth measuring with callipers
    and subtracting 6.35mm.
    You'll also want to bore the internal thread away where it overlaps the o-ring to prevent the o-ring being chewed out. In fact, maybe just do that initially and slip a very fine o-ring over the thread relief area (no groove). The thread will prevent the o-ring sliding off when the barrel is separated.
    Feb 2012
    Tamworth, NSW
    205
    Thanks Jack
  1. Is it an O-ring or a seal
    By Grahame Collins in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 9th Feb 2022, 01:53 PM
  2. Tightening a scroll , self centring chuck
    Last Post: 3rd Jan 2020, 04:43 PM
  3. Wanted - tightening collet on headstock
    By oggy in forum THE HERCUS AREA
    Last Post: 29th Apr 2016, 06:33 PM
  4. Ring making
    By Eindringling in forum METALWORK GENERAL
    Last Post: 6th May 2007, 03:03 AM
