Results 1 to 15 of 16
2nd Jul 2022, 04:23 PM #1Senior Member
- Jun 2012
- ex Perth, now Mittagong
- 105
Brierley drill grinder chuck size
Could anyone tell me what the diameter is of the 6 jaw chuck fitted to the Brierley ZB 25 and ZB 32 drill grinders?
Peter
2nd Jul 2022, 04:57 PM #2Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Chuck size
Hello Peter.
I have a Z25 and I'm sure it's 75mm. I can measure monday if you like.
regards
BC
2nd Jul 2022, 08:10 PM #3Senior Member
- Jun 2012
- 105
Thanks for your reply. I understand that the ZB25 takes a 1 inch drill through the chuck and a ZB32 takes a 1 1/4 inch drill. I am wondering if a 75mm chuck has a bore big enough. Perhaps a measurement of yours will shed some light.
Cheers, Peter
5th Jul 2022, 05:34 PM #4Intermediate Member
- Jul 2009
- Brisbane
- 48
I have a Spiramax, which appears to be the same as a Brierley.
It is a 1/1/4 machine.
The 6 jaw chuck on it is 110mm OD and 33mm ID.
5th Jul 2022, 06:16 PM #5Senior Member
- Jun 2012
- 105
Thanks for your reply. Your Spiromax certainly looks to be very similar to a Brierley so probably a ZB32 would also have a 110mm chuck. I am on the track of a Brierley but I am not sure if it is a 25 or 32 having only seen a photo of it in a partly dismantled state. I will know when I get to have a look at it in a couple of weeks or so. What I do know is that the chuck is missing hence my query. Providing that not too much else of it is missing, grafting a 'foreign' chuck to it may be worth while, there seems to be a few six jaw drill grinding chucks of various sizes available. which could be adapted.
Peter
6th Jul 2022, 04:36 PM #6Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Chuck size
Hello again.
Sorry I'm late it's a busy week.
I measured my chuck and it's 80mm. The bore just takes a 1" drill. A while ago I did a clean of a similar chuck on my form relief grinder and improved it's operation but not the accuracy.
Maybe adapt an ER32 collet chuck to get better concentricity.
BC
6th Jul 2022, 10:13 PM #7Senior Member
- Jun 2012
- 105
Thanks for your reply. Your suggestion re an ER collet chuck could be a way around the lack of a suitable chuck but to do an inch drill it would have to be an ER40. I wonder if the closing nut size would pose a clearance problem when a small drill needs to be sharpened. There are both 80mm and 110mm 6 jaw drill sharpening chucks available new, which could be mounted either directly or via an adapter plate so it looks as if the lack of an existing chuck should not be a definite stopper.
Cheers, Peter
8th Jul 2022, 09:48 AM #8Most Valued Member
- Jul 2016
- 35
- 1,522
You can machine a fair bit off an ER nut at least 3 mm on that outside corner to get a bit more clearance. Still won't be as good as the extended jaws I guess.
10th Jul 2022, 07:26 PM #9Most Valued Member
- 2,651
If you went the collet route you could also use a parallel shank collet chuck of a smaller size (eg ER16 or ER11) and put that in the ER40 to reduce the clearance issues when doing smaller drills.
11th Jul 2022, 10:59 AM #10Senior Member
- Jun 2012
- 105
Thanks for that Steve, I will keep that in mind.
Peter
11th Jul 2022, 03:23 PM #11Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Drill grinder setup.
Hello again.
You will have to be careful when changing the chuck. The drillgrinder is set up by bringing the drill forward to a setting gauge. This gauge is graduated in the drill diameter which in turn changes the stick out of the chuck. You will have to measure this before changing the chuck. Not having the correct cutting edge distance from the pivot point ruins the drill grind. My bad experience there, the manual is not easy to follow and my grinder was set up incorrectly. Had to re time the cam to the spindle.
BC
11th Jul 2022, 10:57 PM #12Senior Member
- Jun 2012
- 105
Thanks for your information. i am leaning towards trying to find the correct 6jaw chuck. providing of course that there is not too much else missing, we will see!
Peter
4th Dec 2022, 05:07 PM #13
Hi Peter, how did you go with your chuck.
I'm rebuilding a Zb25 now. Here's the dimensions of mine.
Od 3.360"
Through bore is 1.005".
Height to face of chuck is 1.730".
Height to jaw face is 2.700".
Depth of register is 0.160"
Diameter of register is 2.460"
Mine is a Burnerd and the part number is either BP69/37872, or 1658-09040.
Both these numbers are stamped on the face of the chuck.
Cheers Alby.
4th Dec 2022, 05:24 PM #14
Second number is the Pratt Burnerd catalogue number, just found the catalogue.
9th Dec 2022, 01:15 PM #15Senior Member
- Jun 2012
- 105
Thanks for the information on your zB25. I have got hold of a manual from Griffith in the UK and I find that my grinder is a ZB21. The through bore is 22mm. there are a few other differences from the ZB25 but I should be able to get it back in operation. I might have to graft an ER chuck on to it instead of a 6 jaw chuck.
6 Jaw chuck size for D1-4
By Maxi77 in forum METALWORK GENERALReplies: 15Last Post: 2nd Apr 2019, 06:41 PM -
Brierley drill bit grinder cams
By nadroj in forum METALWORK GENERALReplies: 6Last Post: 29th Sep 2018, 06:53 AM -
Largest size chuck for 260g?
By ml018 in forum THE HERCUS AREAReplies: 5Last Post: 4th Jul 2018, 07:05 PM -
What size chuck is best ?
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 24th Oct 2011, 11:16 AM -
Toolmaster Tool & Cutter Grinder Workhead Chuck size
By steran50 in forum METALWORK GENERALReplies: 0Last Post: 31st Jan 2011, 10:29 PM
