Results 1 to 15 of 16
Thread: Power Feed On Y & Z Axis Of Mill
26th Jun 2022, 06:43 PM #1Intermediate Member
- Feb 2022
- Mandurah
- 45
- 32
Getting closer to buy a mill and I have the option of getting power feed on the Y & Z axis. Not sure its worth the expense.
Who has it and do they use it much?
Who doesn't and wish they did?
26th Jun 2022, 07:29 PM #2
Hi Chris, Guys,
I would say that "Y" axis power feed is very much worth having ! You will soon get tiered of winding the handle !
The same goes for the "X" feed, not used as much, though I don't have an "X" power feed on mine but I do keep thinking about it. Even less used would be a "Z" feed, mainly used for down feed of a boring head.
A DRO and a "Y" axis power feed would be of the greatest use ! And the most desirable.Best Regards:
26th Jun 2022, 07:42 PM #3
If you have a dodgy back like I have, a power feed on the Z axis is worth every cent.
Winding the table up and down to fit different length tooling all day gets old very quickly at my age.
My BM30A came with X power feed as standard, I had to fit the Z afterwards, which required me to make a longer shaft adapter but it was definitely worth the money and effort.
Thus far I haven't missed having a power feed on the Y axis.
26th Jun 2022, 07:49 PM #4Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 314
Power feed on the 'X' axis definitely, 'Y' yes but you could probably live without it, 'Z' for sure if you're doing any boring bar work. Most times when boring I use the quill feed instead of the table 'Z' axis.
Digital readout ... absolute must on all three.
26th Jun 2022, 11:59 PM #5Golden Member
- Apr 2018
- Drouin Vic
- 634
My frankenmill has power feeds on all axes and I smile every time I engage the Z feed, makes raising the knee a breeze as opposed to hard labour. I use the Y feed all the time too. I'm sure I could live without both but they are nice to have.
27th Jun 2022, 10:10 AM #6Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
I have a power feed on the X-Axis of my BM-20E which like the BM-30A was standard equipment with it. I think a power feed on the X-Axis is a must for a Milling Machine. In the future I will probably put a power feed on the Y-Axis of my Mill, but I don't think I'll worry about the Z Axis.
All The Best steran50 Stewart
27th Jun 2022, 10:49 AM #7Most Valued Member
- 4,258
27th Jun 2022, 05:03 PM #8
I think that there is a little confusion about machine axis !
My understanding is that the "X" axis is front to back. The "Y" is left to right and "Z" up and down !
Or have I got it wrong ?Best Regards:
27th Jun 2022, 05:29 PM #9
My understanding is X is left to right, Y is front to back and Z is up and down.
27th Jun 2022, 06:40 PM #10Diamond Member
- Sep 2006
- 53
- 1,010
XYZ.jpg As WM460 said. The X-Axis is left to right. The Y-Axis is in and out or front to back. The Z-Axis is up and down.
27th Jun 2022, 06:45 PM #11Senior Member
- May 2019
- 77
- 314
27th Jun 2022, 09:42 PM #12
Didn't do a video clip - sorry. I bought it from General Tools (H&F agents)
The issue I had fitting it was that the Z feed handle shaft was around 20mm too long for the adapter shaft supplied in the kit.
I could have cut the original shaft down by that much but that would prevent me going back to the manual feed should I ever have the need (and it smacked of butchery) so I made a new, longer, one.
I drew the new one up in CAD if you ever decide to make the same modification to yours. I also remade the Z axis feed handle to reduce the offset so it doesn't poke out so far.
27th Jun 2022, 10:11 PM #13Philomath in training
- 6,559
My understanding is that X is the longest axis of travel, Z is the spindle and Y is what is left, so on a (vertical) mill, side to side is X, in and out is Y and up and down is Z.
Lathes sound silly, as longitudinal travel is therefore Z, and the cross slide is X.
I agree that pre-CNC terms are easier to understand.
28th Jun 2022, 12:36 AM #14
My HM52 came with X axis feed, then I converted the Y and Z axis to power feeds bought from America at the time as they where to expensive here then.
H&F at the time said they couldn't be fitted, so I fitted it.
I made a new knee shaft to save butchering the original as said above and added a extension shaft to the Y axis.
I couldn't live without them honestly and had them on for around 12 years with no problems other than 1 plastic gear which was my own fault.
Sent from my 5007U using TapatalkUsing Tapatalk
28th Jun 2022, 06:28 PM #15Intermediate Member
- Feb 2022
- Mandurah
- 45
- 32
Thanks guys, Looks like most people see the value. Will investigate further.
Glad I was not the only one getting confused on the axis.
BM-30A Mill - Z axis power feed
By Gavin Newman in forum METALWORK GENERALReplies: 5Last Post: 18th Apr 2022, 09:32 PM -
RF45 Clone Z Axis Power Feed? Left hand crank
By takai in forum METALWORK GENERALReplies: 18Last Post: 17th Apr 2020, 11:05 PM -
DRO & X axis power feed for RF-30 mill
By iron bark in forum METALWORK GENERALReplies: 10Last Post: 10th Sep 2012, 10:05 PM -
Power feed for my mill...
By John Hill in forum METALWORK GENERALReplies: 3Last Post: 11th Jan 2012, 08:11 PM -
Y axis power feed
By HM52 in forum METALWORK GENERALReplies: 1Last Post: 5th May 2010, 03:46 PM
