Results 1 to 15 of 79
27th May 2022, 04:57 PM #1Intermediate Member
- Feb 2022
- Mandurah
- 45
- 32
Lathe tooling and accessories for a beginner
Thanks to all that helped me select a lathe in this thread https://metalworkforums.com/f65/t208148-lathe-2022-a
I am finalsing the order for a AL-336 from Hare & Forbes and want to know what else I should get.
Below is a list of things I think I want but not sure exact item to buy. I believe the lathe uses 16mm tooling.
Any suggestions for these or other things I may have missed let me know.
HSS square bits
Parting bit
Carbide bits
Quick change tool post
Boring bits
Live center
Drill chuck
27th May 2022, 07:22 PM #2Most Valued Member
HSS square bits- 6mm or 8mm for most work. Anything bigger takes forever to grind unless you have a beast of a grinder. You might use a bigger one for the odd form cutting bit.
Parting bit- the US made cobalt HSS ones sold by Eccentric Engineering are fabulous. Mounted in an angled holder, they will save you a lot of grief.
Quick change tool post- An absolute must. I suspect BXA size for that lathe, but don’t quote me.
Live center- you can’t live without one. I recently got one with interchangeable tips and it’s excellent.
Drill chuck- I have two keyless chucks: 0-6mm for small bits. 1-16mm for big ones. Vertex brand.
Lots of other tooling available, but depends what you want to do with your lathe. Restoring a car will require different tooling to model building.Chris
27th May 2022, 07:24 PM #3Most Valued Member
- 5,942
The lathe uses 12mm tooling, you'll find that under Specifications section.
As you're spending quite a bit of money on the lathe, ask them what sort of deal can you get on these; live centre https://www.machineryhouse.com.au/C052 and this set of 7 cutting tools, get extra tips as I found they're not really the best, but then maybe that's my use of them, https://www.machineryhouse.com.au/L0099
There may be better quality tips to suit these Holders, I don't know, hopefully someone will chime in with better details of the tips.
27th May 2022, 07:26 PM #4
H&F are way over priced honestly, shop on eBay from either Australian sellers or from overseas sellers at a further reduction, and there is also AliExpress.
I usually have over 30 order's for all sorts of things coming from AliExpress on my account and now rarely buy from eBay unless it's larger things located here.
You could spend $1000 at H&F for tooling and have say 8 tools, eBay 20-30, AliExpress 50 plus tooling.
I can buy a 16mm turning tool with 10 inserts for $30 on eBay or Ali. You get around 3 working faces (depending on style) on each inserts, so that's 30 faces all up for $30 with a free tool.
Sent from my 5007U using TapatalkUsing Tapatalk
27th May 2022, 08:16 PM #5
Measuring
Hi
All of the above is good advice + you might need measuring tools. I have two of the SHAHE 150mm digital calipers bought from AliExpress , they have been excellent calipers . You can pick up used micrometers i.e. M&W brand on epay . I prefer the older brands when it comes to dial gauges and DTI.
27th May 2022, 09:00 PM #6
Totally agree.
I actually use the $13 dollar dial indicators for lathe 4 jaw setup etc as there good enough for that.
I have probably 12 or more quality indicators and test indicators that live in the cupboard and get used when needed, the cheap ones just sit on the tailstock with the mag base or the mill quill and it wouldn't bother me if I accidentally broke one, which I have done in the past.
It was a good point about measuring gear, you could be pretty well set up to start off for under $200 from AliExpress.
27th May 2022, 09:07 PM #7Golden Member
- May 2020
- Willowbank QLD
- 517
Hello Amused
This may not be the cheapest but I would go this way;
https://www.eccentricengineering.com...nd-tool-holder
Watch video at bottom of page.
https://www.eccentricengineering.com...d-parting-tool
Boring Bar
I would recommend a Keyless chuck.
Morse taper drill set.
Get a good live centre.
Measuring equipment such as micrometer.
I would not get a quick change tool post to start with. Once you have done a bit you can then decide what extra tooling you want and if you want one.
I would not buy anything else to start with. This will get a lot of basic jobs done.
Once you develop your skills you may need more. You will be well positioned to make choices and buy as needed or if a bargain comes up.
28th May 2022, 09:12 AM #8Most Valued Member
- Jul 2016
- 35
- 1,522
I second the diamond tool holder, mine is probably on the machine 50% of the time
28th May 2022, 10:28 AM #9Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
A lot of good advice above. In regards to a live centre I would suggest looking at an extended point centre over a standard point live centre or get both if money allows. I would suggest a pipe centre (bull nose) as well. I know the live centre set has a pipe centre, but it's not that big. As Dave J said shop around for tooling and you will save a lot of money. I've been buying tooling for my Turret Mill mostly from AliExpress such as face mills, carbide inserts and arbors and have saved a lot of money. The quality has been good, but I do look around on there and don't just buy the first ones that I see.
All The Best steran50 Stewart
28th May 2022, 10:46 AM #10Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
Another thumbs up for the diamond tool holders. Make sure you buy both the right hand and the left hand holders. The right hand is the one that will see most use but from time to time you will need the left hand for a particular job. My left hand tool holder sits in the tool drawer most of the time but I used it yesterday to complete a job that I couldn't do any other way.
28th May 2022, 11:38 AM #11Intermediate Member
- Feb 2022
- Mandurah
- 45
- 32
Shopping List
Guys, Thanks for the great feed back. Will look into AliExpress
This was discussed in the lathe thread. Multiple people said it is 16mm and both suggested QCTP they suggest are 16mm. I will confirm before ordering
I want to start with HSS or carbide cutting tools to start with so will definatley get the Eccentric Engineering bits
I already have the following
200mm verniers
50mm micrometer
Dial gauge and stand.
MT2 drill set
Shopping list so far
Live centre https://www.machineryhouse.com.au/C052
MT sleeve so I can use my MT2 drills https://www.machineryhouse.com.au/D422
Extended Live centre https://www.machineryhouse.com.au/C0635
Diamond tool kit https://www.eccentricengineering.com...kit-p178588809
EE Parting tool holder https://www.eccentricengineering.com...kit-p178588809
EE Sharpening jig https://www.eccentricengineering.com...des-p178383140
Questions
What size parting blade/blades should I buy?
Suggestions on the drill chuck, Is the hare forbes ones alright?
Thoughts on a quick change tool post?
Thoughts on 5C collets?
28th May 2022, 12:54 PM #12Member: Blue and white apron brigade
- 7,182
I mainly use 2 and 3.2 mm blades.
A thicker blade is good to start learning with as it's less likely to snap then you can graduate to thinner blades.
I also use pieces of hack saw blades make very thin blades to part Plastic/Al and brass as they waste less material.
https://mcjing.com.au/engineering/chuck-arbor.html
A jaw on one of chucks snapped on first use but McJing replaced the whole chuck immediately - I've had these for more than 10 years - all still good
If you want to get something a little better in quality, the last chuck I bought was from CTC tools
https://www.ctctools.biz/keyless-dri...arbor-1pc-l18/
I bought my QCTP and holders, boring bar sets and carbide sets from ebay/aliexpress etc
28th May 2022, 01:36 PM #13Most Valued Member
28th May 2022, 04:50 PM #14Intermediate Member
- Feb 2022
- Mandurah
- 45
- 32
28th May 2022, 07:48 PM #15
I've had the standard ones forever along with dead and half centres, then probably 10-12 years ago I bought the live centre set with different type centres and cone centres etc.
About 2 years ago I bought the extended centre for the purpose I was sick of having to turn the toolpost to stop my carbide tools hitting the standard one between centres and the carbide threading tool hitting when doing smaller long threads even like the 5/8 10 ACME leadscrew I made around 8 months ago.
For those jobs I need it for clearance, otherwise I just use the standard one.
What Features to look for in a Beginner's Lathe
By 1down5up in forum METALWORK GENERALReplies: 16Last Post: 16th Jan 2021, 11:40 PM -
Insert tooling beginner question
By Danger Mouse in forum METALWORK GENERALReplies: 14Last Post: 11th Sep 2020, 10:20 AM -
Beginner Lathe Recommendation
By drew86 in forum METALWORK GENERALReplies: 4Last Post: 11th Aug 2020, 08:56 PM -
Choice of lathe for beginner
By jordan.lewis92 in forum METALWORK GENERALReplies: 12Last Post: 18th Oct 2011, 03:19 PM -
Beginner Lathe
By browny in forum METALWORK GENERALReplies: 16Last Post: 7th Apr 2008, 08:04 PM
